Please recommend a balanced IEM specifically for the Metal Genres
BasalGanglia
1
47
United Kingdom
I currenty have the Hiby R3 Pro Saber but have just been using standard earphones using the 3.5mm jack. I have just ordered the Hiby R3 II, which has a balanced 4.44mm output. So I wanted to buy a decent pair of balanced earphones that can be used in that port.
I mostly listen to various Metal genres such as Thrash, Death, Melodic Death, Industrial, Metal Core etc so looking for somthing punchy. I was currently using Sony earphones with extra bass (Don't know the model number) and whilst they sound nice and punchy, the quality isn't very good. I have tried more expensive standard earphones that had good reviews but found them to lack bass and therefore sound rubbish for the music I listen to.
My mate suggested the Fiio FH9 but that is out of my budget. The FH7s is £300 in the UK so considering those. I could alwatys go sencond hand though. Would these be good of the genre that I listed to. Does anyone have any other (preferably cheaper) options so look into?
Thanks
