Playback Designs DAC vs. Scarlatti DAC
Congratulations on your purchase and welcome to WBF! Out of curiosity, what is the difference between the MPD-3 and the MPD-5? I know that the difference between the MPS-3 and MPS-5 is that the '3 can not play SACD, but I understand that the MPD-3 can handle DSD. Why would anyone bother with an MPD-5 then?
Hi Keith, I went to the site and believe the MPS-5 can also handle DSD...so in fact, it basially does SACD over the MPS3.
the MPD-5 has a more involved chassis, and all circuit boards are separate with a higher parts count, than the MPD-3. i own the MPS-5 myself.
if you heard the MPD-3 and MPD-5 on separate days you'd be hard pressed to recall any difference. head to head the MPD-5 is more refined sounding.
MPD-3 has fewer inputs, and specifically has no optical input. Fewer parts? Perhaps. Still a substantial piece of equipment at 27 lbs. shipping, 22 lbs. out of box. And that's the DAC only (no CD transport).
Hello, bitstream and welcome to the forum! Congratulations on the Playback Designs MPD-3 purchase. I'm glad to hear you are enjoying the end result.
Tom
That's good to hear. I own an MPS-5 myself also. I have been thinking of going for multichannel SACD, but that would involve buying an external MPD-5 and ganging up my MPS-5 to it. If the MPD-3 is close enough, it should be suitable for a multi-channel setup, you think? To get 5.1 you would need an extra four channels of DAC - very expensive if you have to buy two MPD-5's!!
Have you heard a multi-channel setup with the MPS-5 as the SACD player?
I use my MPS-5 all the time with surround discs/files. The DAC I use is the EMM Labs DAC8-IV. It's the best surround I've ever heard.
when i had my multi-channel set-up for music in my 2-channel room i had the EMM Labs gear with the EMM Labs multi-channel preamp. that was before i got the MPS-5.
