Lampizator Atlantic Plus: stand and power advice
extracampine
13
1
133
I recently acquired a Lampizator Atlantic Plus (balanced and with VC). Great sound. I'm now looking for some advice regarding what to put it on, and also the power supply. I've noticed that if I tap the cable or the shelf it's on then I can hear the sound through the speakers. Keen for any advice in this area!
A lot of people like the Starsound Sistrum Apprentice stand.
Others like footers like Black Ravioli or Shun Mook Ultra diamonds, etc.
More expensive stuff like Halcyon or Herzan electonically controlled stands are also commented about.
Not sure on a Atlantic plus budget you should spend much on the stand and the cable, if you are getting the sound through the speakers, add some weight on top to dampen it.
+1000 on Starsound recommendation. I have all my equipment placed on the Starsound Sistrum Rhythm Platforms, very happy with the result. In my view, Starsound products are quite good and a great value if you compare them to some of the more well known and more expensive rack manufacturers.
Hi Bonzo,
Are you thinking of the Amber 2? The Atlantic Plus balanced with VC is 8,000 Euro, and totally deserving of a couple hundred bucks spent on platforms.
I'm a fan of the Sistrum stuff personally. If that is a little heavy on the budget, their "Apprentice" line is also good.
Hi Bonzo,
Oh ok. Yet my point is save the money to upgrade to upper DHT models. More fun
Apprentice is circa $300.
Apprentice is $300.
Ok, I read the shun Mook, herzan, and cables, and it was too much. Anyway I think his sound problem will be mitigated by damping
Lukasz has his point of view on placing his gear. So the Golden Atlantic has standard "high End" feets, which can be ordered from Lukasz also as an accessory.
Please just check his url, on golden Atlantic he is offering two different feeds, depending on personal needs. Just ask him :)
If you are looking for the best, as the place suggests ;), may I recommend our anti vibration platforms? We pair great with Lukasz DAC's and amps - feel free to contact Lukasz and ask. One condition only - the equipment must have the metal hard footers /which we also supply for LmpizatOr as an OEM/ not the rubber ones. If it is on the rubber, we are about to introduce our own slate CLD footers one can lift the equipment on without any mods. Feel free to ask more if interested.
Cheers,
Jarek
