KT-150 a reality? Are they a drop in replacement for KT-120's ? ...
joeinid
1,543
14
400
NY
Has anyone seen the KT-150 in the wild? I know of one amp that is using it but does anyone think it will be a drop in replacement for the KT-120?
Looks like an egg. That would be cute on my Baby Kronzillas if they can indeed be used as drop in replacements.
I saw them at CAF last month in a new Jolida amp in Greg Beron's room. From what I understand, the new KT150s replace an EL34 so they wouldn't replace a KT120 or 6550 unless the amp is able to use all these tubes.
Perhaps Greg could shed more light on the subject.
Thank you Myles. I am curious about this new tube.
Beam power tube
The plate dissipation is 70 watts
G2 is 9.0 watts,
Cathode current is 275 ma
Filament current is 1.75 -2 amps
Max plate voltage is 850
Screen is 650 volts
Distortion in class A
400v plate
225 v screen
Overall Harmonic Distortion is similar to 6550 at 14%.
Dimensions
Maximum height ..........................................140mm, approx. 5.52"
Balloon diameter, max ................................60mm, approx. 2.4"
Maximum weight ........................................130g
