Krell KBX
martin778
68
12
313
Hi everone!
There is a Krell KBX (late model with FPB faceplate) being offered for sale at a local audio dealer. The main problem is that it is configured for mono use with a Wilson WHOW subwoofer and I want to use it with my JBL 4343's (300Hz/12dB octave).
I emailed Krell three times already but got no answer at all on how to change the crossover slope and frequency in the KBX :(
Can anybody help? Thanks!
If you speak with a good audiotech whose old enough...he may have worked with these in the past and be able to help you. Same goes for an 'old hand' at a Krell dealership/distributorship. I am 99% certain for example if you went to a major Krell distributor like Absolute Sounds UK, their main Audio Tech would know the answer.
Google www.krellservice.com.
Gentleman named Stephen is there. He worked at Krell when this was produced.
