Int-150
Bachtoven
1,007
403
405
Hello. Does anyone here own a Pass Labs Int-150? I recently decided to switch from surround sound to stereo, so I sold my Marantz 8801 pre/pro and Parasound Halo A51 and bought the INT-150--wow! It is much more transparent and detailed--everything simply sounds more real.
Yes
Hi Bachtoven,
I've been using the Int-150 for the last 5 years or so and never once did I encounter any problem whatsoever with this amp. Its so reliable and the built quality is as solid as a tank. Sound wise, I can't complain at all with this price, it gives me all the sonic quality that I need or want and more. Now, I'm just curious about Pass new INT-250. Anyone heard it yet? Would appreciate some feedback and comparison with the INT-150 if possible. That would be next target, after 5 years, the upgrade itch is in the air. Meanwhile, sit back and enjoy the Int-150, its a real performer that can give some of the separates a run for their money.
depending on your speakers, an upgrade to the INT-60 might be an even better (and more afordable) deal
My speakers is rated at 90 db/m on 4 ohms, not sure if that is consider an easy load to drive. However, I'm getting conflicting reports on the power rating for the Int-60, some said its 60 watts while I've read others saying its only 30 watts, so I'm confused as to which rating is correct. If it's 30 watts, I think its a bit on the low side for my taste as I love amps with drive and weight. I listen mainly to acoustic jazz standards, so speed is critical to me. I love beefier amps for the grip, especially on the bass section.
I've decided to sell mine. It sounds great, but I think I'd prefer a tube amp. See the Buy/Sell thread.
