I won a power cable…where should I put it?
Zuman
277
444
135
73
I won an M101 Flare power cable in a drawing at AXPONA last weekend. I like M101 a lot…they make great cables, but I haven’t previously invested much in power cords. I presently use a few Viborg and Pangea cables and an old Zu Mother cable.
So - assuming that my new M101 is my best power cable (and I’m confident that it will be), which component should I use it with (list in my signature below)? Or should I feed my PS Audio regenerator with it? (I have my amp plugged directly into the wall, but everything else goes into the regenerator.
Thanks!
Reactions: Republicoftexas69
Based on my experience power seems to make the most difference in amplification. So I’d start there. Then it would be a good test to swap with the regenerator and see what that sounds like. You may prefer one over the other or you may love both in which case you’ll have to make a choice. Or get another M101 Flare!
I agree you should try it in your MW225i
Thanks!
Source or power amp.
