regarding the rack question; I think that the TS-300 is the wrong choice for a number of reasons. the AVI units are simply better performers as they are larger form factors and so enjoy that advantage for better performance, as well as being much cheaper, and have the added advantage of using the LFS unit to improve performance. the auto leveling feature of the TS units has no benefit in our application how we will use these. and the Nanodamp NWD 23A series platform is engineered to be the perfect solution already and there is no need to make it different. it is designed for 660 pounds/300 kg.
I've requested a few modifications which the techs at Herzan are reviewing; (1) linear power supplies, (2) moving the control unit to the rear to allow for more space for (3) shelves, (4) plastic caps on the legs for sand or shot fill, (5) either large screw flat feet or spikes, and (6) possibly taller to both accommodate more shelf height and allow for a better working height for cartridge/arm adjustments and record on and off.
I realize David's perspective on the thick steel top plate. but you are going to have huge bass towers in a much smaller space than David has. those bass towers (like mine) will cause feedback I don't care how much mass you have.....it's just physics. David's bass units are much less intrusive and over 30 feet from his platform. think about it. and a sandwich/breadboard type of top surface has properties more appropriate than thick steel in terms of energy retention. ask Tim or Reid about that. Taiko Tana have done investigations into this question.
there are similar capacity 'standard' Nanodamp NDW racks which would match the look of the active shelves, so you could use 3 of these and get the tech you want with each. and they are already designed for the task.
Dear Mike,
The NDW-23A does indeed look like a good solution. I like the LFS option, too.
A few months ago I asked Tim about holes and caps to fill the legs with sand or steel shot. I also asked about flat feet versus spikes.
Tim said at that time that his people did not perceive any difference in TS active isolation performance between flat feet or spikes.
I am quite sure I am going to place the Aesthetix Io control unit on a TS-140, so I want any other Herzan stand to match the custom stand for the TS-140.
I appreciate your suggestions on the tabletop. I have plenty of time to figure out the tabletop solution.
All of the components except the VTLs will be located in an adjacent equipment room, out of the line of fire of the speaker columns.
