Herzan Question
Kingsrule
1,636
892
1,930
I have one TS140 to install in an all server system.
So where would I get the most benefit?:
1. Under the 4 bay QNAP
2. Under the Rossini, which is also used as preamp
3. Under the computer (has ssd) running roon
my 'guess' is the Rossini would end up yielding the greatest benefit. I have mine (TS-150) under my dart pre which includes my phono stages. it is somewhat system dependent based on the amount and proximity of low bass sources in your system.
you can also experiment with 'stacking' gear making sure you block noise pollution from one box to another. I did stack my Playbacks Design digital on top of my dart pre for years both atop the TS-150. I used a Symposium Svelte Shelf between the 2 boxes as a sort of noise reducer.....otherwise my phono stage performance was compromised. it improved both the dart pre and the PD.
ideally the TS series platforms work best on a solid grounded rack on a concrete floor. you want to remove any compliance from whatever it sits on. then it is allowed to decouple the target gear most effectively.
ML
Thanks for your input
I bought it thinking it would be best to isolate the hard drives in the QNAP, much like isolating a TT, but I see you and others use it for your front end components.
Have you actually tried it under your hard drives?
