I took the time to play around with the settings in my A/V processor the other day. I have several thousand CDs and lots of music files on my server (all in stereo or mono) and tried playing some of the ones I know well using surround sound processing modes, mostly Dolby ProLogic IIX Music.
The following are my impressions:
Cons:
1. The processing obviously adds a bit of artificial "glassiness" to the sound (must lie in upper midrange/lower treble). This effect may be system dependent, etc.
2. Setting the channel balances correctly is almost a "by the album or track" procedure, because each recording offers up a different amount of the out-of-phase information, etc that is used to create rear channel signals. So, some recordings can use up to 3-4 dB more surround volume than others to achieve the same level of effect. For the record, I'm not a fan of sitting "on stage" with instruments popping up all around me.
Pros:
1. For several of the recordings, after setting the surround level to a reasonable amount, there is a quality added to the presentation that absolutely provides a missing portion of the "reality" illusion. While I'm sure this effect (and its degree of absence) are very system dependent, there was definitely a sense of dimensionality that simply cannot be fully reproduced by stereo (of the many systems I've heard personally).
2. Having more speakers playing, it seemed as though the dynamics of the event (and their bloom into the recorded space), were more accurately portrayed. On bigger systems than mine, it's quite possible that this impression may be reduced or eliminated.
Overall, the effect is varied and the recording has a great impact on the enjoyment factor. Michael Stearns' The Lost World was fantastic through the surround presentation, while other albums were less so.
I'd be interested to hear the thoughts and experiences of others here! I know I'm fiddling with one of the most sacred audiophile dogmas......
Lee
Cons:
Pros:
Lee
