Have you?Did some of you try the Synergistic Research Orange Fuse on your Diablo 120-300 ?
Is it worth it and which model fuse do i need ?
Yes i have the new SR Purple fuse, it's really amazing!Have you?
Thanks for your response,Yes i have the new SR Purple fuse, it's really amazing!
I replaced the 6.3A one at the back of the amp.Thanks for your response,
Which one did you replace? just the 8A one?
Is it a big difference over the stock fuse? What difference did you notice?
Have you tried the QSA fuses?
Thank you - Did you pick slow or fast for the Diablo? And which direction worked best for you?I replaced the 6.3A one at the back of the amp.
Also replaced the ones of my Aqua LinQ and Formula DAC.
You get more transparency, wider soundstage and a more holographic.
Only tried SR Purple fuses so far and don't plan o trying any other brands.
You need slow blow.Thank you - Did you pick slow or fast for the Diablo? And which direction worked best for you?
Thanks, I placed the order, will report backYou need slow blow.
Direction is S at the back and R towards the front of the unit.
Hi,I'm currenty testing Gryphon 120 with Sonus Faber Electa Amator 1. It's running up against my Jadis da88s. The result:
I'm seriously thinking of doing a swap. Great amp.
Hi ,I'm investigating integrated amplifiers to power my new Harbeth Monitor 30.2 Anniversary Editions.
Do we have any Diablo owners in the group? I'd appreciate your comments.
Edit: Specifically the Diablo 120.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
