There's a killer deal on newYamaha AS2000 IAs over on Agon.
Hi Rich, it's actually our conversations about the SP-9 that has me thinking/considering the SP17.
If/when I'm in a position to part with it, you'll be the first to know!
Another alternative, if you want to go the IA route, is PrimaLuna. The DiaLogue One or Two should be within your budget (just).
i think its common to go tube/pre, ss amp. however, it really probably makes more sense to go the other way due to impedance issues.
i think ultimately people go tube preamp because there are few tubes (and don't have to be replaced often)---but since preamps have gotten more SS over time, i think if you want tube sound you need to go tube amp. tube preamps just don't layer like tube amps and tubophiles understand what i'm talking about.
just my 2 cents
There is no doubt tube amps can be high maintenance however some more than others and still others that are very little or none at all and YMMV
Hi John,
I think I have finally found the right balance in my system. I use a tube preamp,tube dac and a SS amplifiers driving my 96db efficient speakers. I have a big room but I sit about 13 feet away from them. I like the transparency of tubes with the power of the SS amps. I could go back to tube amplifiers but they are high maintenance. I can deal with tube preamps because I have yet to hear a SS preamp having the presence of the tubed version. FWIW and YMMV
