I think it depends on how your system will be configured. If you plan on a USB source being the primary source or a transport which has the capability of accepting a clock signal, than the clock may add value. The up sampler allows you to use the network streamer functionality of the up sampler and provides the ability to feed the DAC with dual AES feeds that I have found to positively impact red book recordings. The up sampler also allows you to use the dCS app for control. I do not have the transport but do have the DAC, clock and up sampler....80% of my listening is using the up sampler network streamer controlled by the dCS app. I have yet to find a combo that surpasses the performance of this system IMO
Unfortunately all the people who had experience with the complete Vivaldi system told me that a CD played using the dedicated transport sounds significantly better than the ripped file played through a music server. As my digital listening is currently 100% red book, the system becomes too expensive.
I replaced my Scarlatti Transport with a Vivaldi Transport today...only 2 hours playing time...it's simply better. I won't sleep this weekend...
Congrats! You have simply one of the best systems out there.
Congrats!!! Big move!!! How is it simply better? Most curious!! Enjoy the sleepness nights!!!
How...first off...dCS Scarlatti had state of the art bass....I swear...the Vivaldi Trans makes the Scarlatti Trans sound fuzzy. Next thing is the precision of the timing and how the images are placed in space...the instrument images are smaller...but in a larger space...so the guitar isn't 6 feet wide...but again...I NEVER noticed that with the Scarlatti..only in comparison...and this is just with a few hours...I am sure I have a lot of break in to go through...
Well...I thought the Vivaldi DAC and Trans with the Scarlatti clock was just killer good. I reluctantly bought the Vivaldi Clock, might as well have it all match
I've had the Vivaldi Clock now for 48 hours. And once again the performance takes a pretty good step up. Vs the Scarlatti clock, music is unraveled with more ease, there is better focus/placement of images, it's more powerful-yet more delicate and better resolution all over. I could hear the the change on the first note played...it isn't subtle.
It's been a fun journey to do this one piece at a time. First replacing Scarlatti dac with the Vivaldi dac...then replacing the Scalatti trans...the finally the Scarlatti clock. All else in my system has been constant. As for breaking it felt like the dac took about 2 months...the transport about a month and I don't know about the clock...maybe more will happen since I only have 56 hours of it being on...
Happy listenings with your new DCS combo! I am sure Scarlatti was also a fine gear I guess what you are hearing with Vivaldi must be a significant step ahead. Comparing these 3 (dac, transport, clock) as you put them into your system one by one, which one do you think has made the most dramatic impact? Is it DAC or transport if not clock? I consider Vivaldi transport + dac (dont have space for clock) to replace my EMM Labs XDS1 one box player as a future upgrade path and would appreciate your feedback on Vivaldi upgrade over Scarlatti. Thx.
