Dark sounding gear
All amps do. It's just a matter of nature and degree. Now behave and stay on topic :p
Sins of omission?
4pm. Bright, sunny afternoon. Hot as usual.
I think having a reference to audiophile terms is a good way to understand what the terms mean and provides a consistency to the meanings. Without a reference, the terms would morph from one meaning to another, depending on the group discussing them. Stereophile created just such a reference many years ago. Here's the link...
http://www.stereophile.com/reference/50/index.html
dark A warm, mellow, excessively rich quality in reproduced sound. The
audible effect of a frequency response which is clockwise-tilted across the
entire range, so that output diminishes with increasing frequency. Compare
"light."
Clock-wise tilted? Sounds like way too much audio geek-speak to me.
Let me attempt to explain. Imagine a frequency response line, horizontally flat on a graph. Now, imagine the entire frequency response line rotating clockwise. The effect on the frequency spectrum would be dark, as the lower frequencies (those to the left of the pivot point) would be greater, while the higher frequencies (those to the right of the pivot point) would be lower. Now, contrast that with imagining the frequency response line rotating counter-clockwise. That subjective effect would be light sounding.
Please excuse any dramatic prose below, I'd just seen the Hobbit ... where darkness will soon prevail ...
"Dark" sounding hi-end equipment certainly does exist to my ears. Certainly some gear seems rolled-off (ie: early Rowland) and therefore is deemed "dark"; however at this level (top grade equipment) it's rarely a simply frequency response issue.
No, to my ears it's very much a matter of contrast, a kind of ratio, in the same vain as video contrast. Some gear tends to sound darker within the spaces behind the notes, like a pervasive black background shadow, such as Krell's early class A based amps or my Classe DR3s, which are considered dark sounding amps by many, including myself. In all honesty, I find most good Class A driven amps sway towards the dark side.
Over the last decade, to my ears at least, as more & more equipment has moved towards IC/computer technology, the result has been an overall brighter and certainly more analytical presentation. I understand that's a vast generalization, and it is, but to my ears, older discrete based equipment is consistently darker hued in comparison to current gear.
The thing is, many people will consider that overall detail always suffers at the hands of darkness, but although that maybe true in many cases, it's certainly not the rule. I've heard power-line conditioning darken a system "black" while still enlightening detail retrieval. On the other hand, the Technics 1200, despite what the many fan-boys creed, will generally always provide a consistently dark and narrow tonal picture - dark; but void of inner detail.
Amps are one thing, pre-amps and source components may also fit within a contrasting scale. Lyra for example, is rarely considered dark, but the latest Ortofons might be, especially in comparison.
Certain colorations have long been considered a "negative" thing within most audiophile circles, but to me, that's simply being far too dismissive of the available hues good equipment may provide. Dark & bright are simple words that many people simply take for granted ... a dark mention will often be perceived as "too dark", same as bright, ... but do these terms truly provide you with a picture of the components true musical delivery?
I don't think so ...
tb1
