interested in hearing some feedback from any users- how dos it compare to other p/c out there?
what are the main attributes and usages?
Thank you A/E- that's what i'm experiencing, but only with the front end , so far.the 909s go straight to their 20 amp dedicated outlets.Didn't realize there was not yet a 948 thread on WBF.
It's a great unit, it serves 2 functions, DC voltage elimination (at all 8 sockets on the unit + any neighboring sockets on the same wall outlet) and as a high frequency noise filter (on the upper row of sockets on the 948 although this is customizable). It work's in parallel to the mains (it does not regenerate) so should not be current restrictive (on the non-HF filter sockets). HF filter sockets are for source components, preamps, etc.
It helped sweeten and purify the high's on my 911mk3 but have not done much testing since I have switched to the DartZ 108. Some users have reported better dynamics (macro and micro) with the power amp bypassing the 948 (but still benefiting from the DC correction), but I personally have not found this to be the case.
No comparative experience with other conditioners, I went straight for the 948 when I had hum issues with my 911mk3 (high DC in my mains - I live in an apartment building).
Ozy, this is Vincent from Taiwan. As Aidio Explorations has explained the function, so I will just express my impression about comparing 948 to other power conditioner. I have used several ones before including an older 948 model (yes, I sold the older model and buy a new one with detachable power cord), most of the power conditioners have their own sound signature, to name a few PS 300, 500, PS Premier, Hydra 8, Transparent, and Richard Gary, etc., but 948 is 2 out of there has no sound coloration, the other one is Titan.
And 948 is really system depending and depends where you listening environment is, if you live in a quite neighborhood with less outside noise, you will be able to hear more music detail through the 948 and music become liveness. If you live by the street with a lot of traffic outthere and dirty electricity supply, then probably the other power conditioner will be more suitable for you.
Very nice comparisons. I own the Transparent...what kind of colorations did you notice it had? Curious to know. Thanks!
Hi, I use several Transparent cable and PIMM 2 now so I am kind of familiar with Transparent house sound, IMHO, it is a bite dark, airy and open, the higher level you go the more power and transparency you can get, but the sound signature is about the same. Please note all the description are relative term when comparing to other brand of cable. When I use the PIMM 2, I felt like I added another Transparent cable into the system (and higher level one), since I like the Transparent sound so I keep it in the system. Try something different and you can easily find the sound signature of Transparent.
Glad to have helped out Lloyd. I'll get you onto balanced power eventually, I vow it!
Hi Lloyd,
I thought several times of selling mine, until I took it out of my system. Everything fell flat, like something was missing. I have no plans on getting rid of something that does a superb job.
Congratulations on a great conditioner.
Hi Lloyd,
Hi Joe...just sent you an email on CJ GAT/Burmester 948.
Thanks Lloyd!
Yes, just saw it. Will respond soon. I am so glad you are happy. I never want to get rid of mine.
