Bi-wiring and amp load?
caesar
971
1,698
I have heard bi-wired systems sound more dynamic than single wired systems. Bi-wiring seems to be artificial way to improve the power of an amp.
Does anyone understand how this works?
There's a thread in the tech section about bi-wiring. I see no way for it to audibly improve the sound of an amp, and there is no way for it to increase the power of an amp. I have yet to attend a bi-wire test where it made a difference, or a difference not equaled by simply using a larger (single) cable.
Disclaimer: I am not in general a strong advocate for wires beyond large enough to do the job. Others have far more experience with wire swapping and will chime in, I am sure.
As always, YMMV - Don
As always, different does not forcefully mean better.
I have read that some manufacturers intentionally do not have bi-wiring because they fear that customers using two different types of wires in the bass and the treble can ruin the sound of their speakers.
Wires, more wires ...
Bi-wiring, Tri-wiring, Quad-wiring, it all adds up to adding more wires, more cabling,
but not more ampying, amplifying, powering.
And there is nothing wrong in adding more and higher cable gauge to your system.
Loudspeakers that allow bi-wiring are simply providing more flexibility and potential sound benefits.
* As for the true real benefits of bi-wiring, simply put:
-> It can improve clarity and openness, and provide more solidity to the bass.
{As it only requires two additional speaker cables,
it is also a low cost way to achieve even better performance from your loudspeakers.}
** And as for the technical advantages of using more cables, or higher cable gauge,
and to each driver of a loudspeaker:
-> Cable resistance, cable inductance, and cable impedance ...
1. {A cable's shunt capacitive reactance, should be as high as possible.}
[Cable capacitance should be as small as possible.]
2. {A cable's series inductive reactance should be as small as possible.}
[Inductance should be as small as possible.]
3. {A cable's series resistance should also be as low as possible.}
