Your personal reasoning is incorrect. Delrin and similar plastic-based materials have a “plastic” sonic character and tend to smear the sound. Since Delrin does not have the density of metal, it cannot be used to create a truly high-mass platter, which is essential for high-performance turntable design.
In contrast, high-mass metal platters do not inherently ring when engineered properly, and they can be effectively coupled with other materials for optimized isolation and damping. Plastics like Delrin are relatively soft and absorb mechanical energy—including the micro-vibrations read by the stylus. That means part of the musical information is lost.
If using soft materials were the key to superior turntable design, then platters would be made out of sponge—because sponge is even more “dead” than Delrin.
Keep in mind that higher-performance plinths, platters, cartridge bodies, armboards, etc., are all made from harder, stiffer materials—typically metal.
