Alright - I got one...The Gryphon Exorcist - Why Does 'Demagnetizing' Seem to Work??
LL21
15,363
3,182
1,998
This is a strange one. When i got my Gryphon Colosseum second hand, i ended up with the Gryphon VIP Ref Powercable, and the Gryphon Exorcist demagnetizer as well.
the first two...no contest...totally happy and everyone can understand the science, the listening, etc. But the Gryphon Exorcist? I have to admit...not sure why, but something is better. Like clearing wax out of the systems ears if you will. It emits a tone thru the entire audio chain for 35 seconds, and it always seems like the system is clearer, slightly fuller. why?
I decided to avoid any kind of 'memory' issues....and i played the unit thru 1 time...35 seconds of this tone. And then play the unit again to listen to the same tone. And the 2nd time it was 10% louder, and the lingering decay at the end as it faded away was longer. The 3rd time was about the same as the 2nd.
So is it actually doing something? Anyone?
Wonder what the difference is between the Exorcist and Esoteric disc (that's been sitting here for ages but still haven't tried :( ).
My car drives better when it's clean. (True).
I use the Walker Talisman (a handheld demagnitizer) on my vinyl. Seems to make a clean record a little quieter, but who knows- I may be crazy.
My wife takes our cat to a witch doctor- the cat gets reiki, accupuncture, etc. and always comes home with a bounce in his step.
I have not tried demagnitizing the cat.
:D
The least said about said devices, the better .. If one finds it makes a difference do enjoy it.. That's what we are in this hobby for ...
Hmm, maybe I should demagnetize my wife. Is that one of the buttons on the "Stepford Wife" remote control?
Yeah, demagnitizer so she lets you go to RMAF.
Lloyd that's really worth a separate thread- why does exorcism reduce system noise and heighten small details?
Frankly, it's enough to make your head spin. :)
Reactions: rugyboogie
Hah!
Lloyd - I also had thoes two Gryphon appliances, both worked pretty well, I am sure you know they work ONLY with SS units thou! - if I recall it right, noise floor was a tad down.
Really, I hadn't heard that?
I hadn't either. Seemed to work fine for me. I will say, i would not have purchased it, but when i bought my Gryphon Colosseum 2nd hand, it came with the Gryphon VIP Ref Power Cable and the Gryphon Exorcist.
great...the question is does anyone know why? It reminds me...i have not used it in a while...i found it had less use once i put in the Tripoint...but I should try it again.
Reactions: jorgep
