Allaerts MC1 Boron
puroagave
1,377
73
1,620
FS: Allaerts MC1 Boron, excellent physical and operational condition. The cantilever is straight and true and channel balance is excellent. the former owner was meticulous and documented every hour of play (244). I added less than 6 hrs which puts it at 250. Build date is late 2007 and was checked out by Jan since then.
SOLD!
TECHNICAL SPECIFICATIONS
Jan Allaerts MC 1 Boron
Casing Manually milled and drilled aluminium
Cover 0,3 mm thick, coated with 24 ct. gold foil.
Color Anodized in gold-colored finish (scratch resistant)
Terminals Soft iron, shaped by grinding and milling.
Connector pins 1,3 mm x 20 mm, 14 Kt. solid gold pins.
Screw bushes 2,5 mm brass threaded bushes mounded into casing.
Magnet Rechargeable principle
Power: max. BH (Kj/m3°) 41
Coil 2 mm x 2 mm, soft iron type c 1003 (handwound).
Coil windings 15 micron copper hand-winding wire.
Stylus holder Boron 0,3 mm x 7 mm
Angle of stylus in holder 20°
Stylus tip TIP FGS. High-tech diamond, highly polished finish.
Rounded radius 2,5 micron.
Shock absorption High-tech rubber, 100 SCHOR
Tension wire Steel wire spring, code 1007.
TECHNICAL DATA
Coil impedance 22 Ohm
Load impedance 100 Ohm
Load capacity 150 pF
Stylus pressure 2 grams, Max. tolerance 0,1 gram
Output voltage 500 µV
Max. tracing capacity 200 µ mm
Channel separation 60 dB at 100 Hz
50 dB at 1 KHz
50 dB at 20 KHz
Frequency range 10 Hz to 50 KHz
Total THD % 0.5 %
Total unit weight 10 grams (incl. socket screws)
The technical data specified above
are dependent on the actual arm
used in the equipment. Test Equipment :
Goldmund Turntable / Air Tangent arm with exterior wiring
NEUTRIK AUDIO TEST A 1 and TP 402
Rob-Since you put less than 6 hours on the cartridge, I'm guessing you don't like it.
it doesnt like my arm. you cant adjust overhang with the WTT amadeus, that and the allaerts 10g of heft are better suited for a different arm. me thinks it would sound killer w/ the Ikeda or 12" SME ;)
Yeah, I heard it really sings with the SME 312S arm.
