All NEW Final Audio Model 15 Electrostatic Loudspeakers Review : Taking Electrostatic Loudspeakers To A Whole New Level !
Paul graciously hosted our group to hear the Final M35 ESL. They were perhaps not fully broken in yet. I came away thinking they had promise, but I noted some limitations. I missed another opportunity more recently to hear them with the big Krell amp. I would like to know how they might have improved.
I am intrigued by the Diptyque panels which I’ve heard at a High End and another show. They take the basic ideas of a Magnepan or Eminent Technology design and improve on all facets. Magnet elements are placed on both sides of the diaphragm increasing flux density, the frame is stiffened, and better crossover design and parts are evident. The DP 140 and DP 160 are reasonably priced.
Hei,
I haven't heard the Final speakers yet. But I'd like to. I recently heard Popopri, which I liked a lot. The newer ESLs use new materials that improve the sound of the ESLs.
But I'd like to share my personal impressions of ESLs with you. Of my ESLs. I myself have Audiostatics. More specifically, Geschka ESLs, which were an improved Audiostatic versions. However, these older ESLs aren't quite comparable to the quality of newer ESLs. But the newer ESLs still have to contend with the same physics. So mine can serve as an example.
My problem for a long time was the somewhat ethereal sound. Of course, they were fast and spacious. But they always lacked a certain physicality, which offer other speaker principals, such as dynamic speakers. But Peter Walker once said, that the height of the ESLs represents the dynamics, and the surface represents the bass. So I got a second pair for the bass range only. In my case, from just below 40 Hz to 500 Hz. I use two amplifiers for this.
Even after adding a bass ESL, I still don't have dynamic speakers. But the sound is now much more grounded. And that's what I was aiming for. And to some extent, I got it. Especially as my ESLs lack of volume in the 100–300 Hz range. I still cant keep up with a newer ESL, but that was not to expect.
What I want to say overall is, that many of the small and narrow ESLs, which are often made for WAF reasons, probably still can't provide enough substance to the soundscape, despite the latest materials. And that's the impression many people may get at HiFi shows. And now back to the Final M35. These wings alone will help improve the fundamental tone. Additional their bigger surface area than the smaller models supports Walker's approach.
Even nowadays, it's just not possible to buy narrow and small-area ESLs or panels, if you have high expectations. So you need the likes like M35, a large Popori, or another large panel. Bigger helps a lot. I can't say whether hybrids are a solution, I had not the chance to listen to them at home. But companies like Martin Logan get a lot of credit.
But what I also get with the second pair of ESL is what Magnepan calls power response. The way the room is filled. I think it has to do with the amount of air which is moved. And this is more easy achieved with enough driver surface. Therefore my bass panels fill the room more gracefully. Even dynamic speaker profit from this. That is why Final sells a bass tower. A single driver cannot do this. I heard smaller speakers dry to do this by using a bass driver which larger membrane strokes, but as soon it gets louder, they always sounded kind of strained to my ears. But if you are used to the rather gentle movement of big driver surfaces, you cannot go back to this smaller kind of athletics loudspeaker. This is only my impression.
Greetings Wolfgang
Bass is not one of the shortcomings of the Final Audio M35s. In fact I would argue that at least the early version of the speaker that I have overemphasizes the bottom end a little bit and in my room there is a hump between 50-100Hz that I have tried to tame with PEQ in Roon. Now it is possible that is just a artifact of the room but @Riverdinaudio has also noted it in conversations with me. I also feel the top end is a bit rolled off for my tastes and overall (again in my room) the speakers measure as if they were designed with more of a Harman curve frequency response rather than flat. To some extent I suspect that is an overreaction to popular concerns about electrostatics being too bright and bass light which is certainly not the case with the M35s I have. However, even without any tuning the M35s have notably better and more textured and tuneful bass than the Magnepan 20.7s that I used previously which were no slouch. The M35s do provide a fantastic soundstage that is deep and wide and very precisely positioned and detailed. They are very holographic, although still not quite at the eerie level of a Quad 57. And I simply love the timbre and tone of the M35s. Listening to a track like this is practically orgasmic on well set up M35s. https://open.qobuz.com/track/6825966 Things like drum skins, chimes, tenor sax etc. is fantastic. I love "Seven Pillars" but the "mARImbA" https://open.qobuz.com/track/130093496 track sounds truly special and there is no lack of bass or dynamics playing any of the album.
Still, dynamics aren't as good as what a truly excellent box speaker provides but for the kind of music I listen to that isn't much of an issue. Where the M35s are lacking is in the attack and transients that a great "fast" speaker provides. Recently I set up a pair of Klipsch La Scala's in my second system with a well integrated subwoofer and even though they are clearly not as "good" as the M35s they are very fun to listen to on some music largely because of the sense of immediacy, and their better attack, transients and dynamics. However, I have auditioned both systems for a half dozen people and there is no question that the M35s are better.
I heard the smallest Popori WR3 at T.H.E. show last month and was quite impressed with it. It also has excellent bass response and is a bit cheaper than the M35. I suspect the higher end WR1 with its ribbon tweeter is very good but at a significantly higher price. I also heard the Diptyque REFERENCE MK2 which is their top end model at $60K. It was well set up and sounded very good but for whatever reason didn't captivate me. The Clarisys Studio Plus was also excellent and also in the $60-70K price range. None of those speakers had any noticeable deficiency in bass. I think in general the technology in the latest generation of panel speakers has gone a long way toward overcoming most of the criticisms of the past. Which one you prefer is probably a question of personal preference and budget.
Hei Paul,
I think you did very well with the M35. And you cannot have done much better. The M35 is the pinnacle of today panel technology, where only a few belong. Mainly the ones you already mentioned. I am a little bit surprised as you said, that the bass is no longer an issue. That is welcome news. Of course horns dominate in attack and transient. In this respect they are a class in their own. But unfortunately it's the only area where they seem to shine. In the sum of all criteria I always prefer panel speakers. Second comes bending waves speakers. For years I had Manger speaker. Which I still like.
Of all speakers I like the least are the typical dynamic speakers. Although they have made probably the most progress in the last decade and can sound stunning, but I still feel the disadvantage of dynamic drivers is hard to overcome and encloses always sound like encloses.
You did choose the right speaker. The only thing left for you to do is listing to music.
Greetings Wolfgang
Reactions: LiquidSound
Hei,
Greetings Wolfgang
Great post. I am currently enjoying a pair of modified, uncovered 3.6R. These are definitely more dynamic than my 3.7i were. a friend is rebuilding a pair of Tympani 1-D Magnepan bass panels for me. A faux Tympani 3a?
I have a SoundLab Majestic 845 based system. But my son has a La Scala 2-channel system and I 2nd., you comments about them! He's also running 5 Klipsch Heresy's (Fronts, Center, & Sides) in a 7.2 surround system & they work quite well.
Over the years, after using Energy Speakers & then Martin Logans as surround speakers, I'm happily using Klipsch in my current 7.2.4 Home Theater. Considering how important the center channel is, the Klipsch's clarity is hard to beat; thus, for the price, Klipsch are outstanding for 13-speaker Surround Sound purposes.
@Paul1960, Owning 3-different model SoundLabs for over 25-years, I enjoy amplifier conversations about stats. and appreciated your addition to same, primarily found here!.
My SoundLab amp journey began with a Mark Levinson 336 (350W stereo amp) which I owned.
I choose the Levinson 336 in a shoot-out with Krell FBP 600's. But, that's when I owned Martin Logan reQuests (NOT SoundLabs). In those days, if the shout-out was with SoundLabs, the end result may have been different.
Later, with my SoundLabs and Levinson combo, I simultaneously auditioned Parasound Halo JC1's and Convergent Technology (CAT) Triode JL1's. I didn't leave the Parasounds in long enough to draw a good comparison against my Levinson. But the Parasounds were good/similar and at a lessor price. But, when I inserted the CAT's, they were in another time zone. The CAT's (meow) controlled the SoundLabs like neither solid state device and everything audio wise I appreciate/prefer, was better! Thus, those ~190lb.ea. (big) CAT monos remained, & the Parasounds were returned, along with my Levinson (which I traded-in for the CAT's).
However, since my first SoundLab pair, improvements have been made in the panels (which are now "PX" ones) and in the transformers. Those changes have made the SoundLabs quite a bit more efficient & easy to drive.
Later, I moved from the CAT 100W (16-power tubes) JL1's, to the 150W (32-tubes) CAT JL3's and then later, to Atma-sphere MA-1 OTL's, which I now own.
Thinking of going back to solid state, but keeping my Atma-sphere's, I've found a recent SoundLab specific discussion started in wthatbestforum here by jeffreybehr. He went though several different amps as follows (in no particular order):
PS Audio BHK-600's
Pass XA-60's
Atma-sphere MA-1's
Pass X260.8's
Berning Quadrature Z's
His favorites were the PS BHK600's, Pass X260.8's and Pass XA60's. He chose the later pair (XA-60's) to use with his new SoundLabs.
Assuming SoundLabs and Final stats similiarly respond to amplification (?), I thought I would add to your amplifier experiences in hopes that they may be helpful to folks thinking of stats or owning stats.
BTW, FWIW, SoundLabs can now be ordered in various heights (beginning at 5') and widths, that can more easily fit one's room and aesthetics.
Hi All... I'm brand new to this forum and looking forward to learning and sharing experiences with you all.
Hopefully, my Final Model M12+'s will be delivered sometime next week. I have been waiting for them since mid-February. After looking at all the color options for the stators, I chose clear. With that change they apparently had some issues with the electroconductive coating they print on the stators as it had a bluish tint to it, and I guess changing it to eliminate the color created an issue with the coating that had to be overcome. In retrospect, I'm glad it took longer to get them as they now have a new control board for speakers manufactured since June. They've been in final testing and 50-hours break in since last week and are supposed to ship this week. I'm certainly looking forward to getting them ! I have had both tube and solid-state low-powered amplifiers in the past as I have 98db efficient single driver speakers, however the M12+'s will need notably more power than those amps can deliver. I have an Accuphase A48 stereo amp and recently purchased the new LAiV GaNM monobloc amps. With my modest listening space (10-ft X 12-ft) I'm hoping the A48 can drive them to my normal listening levels, which I believe it will. The LAiV GaNM's work very well on my single driver speakers and are dead quiet. LAiV has done an excellent job with all of their products and these new amps are no exception.
Congratulations on the new speakers. I will be interested in hearing how well the LAiV GaNM's work with the M12. I have been very happy with the LAiV uDDC that I bought.
I believe Joey G who has a channel on YouTube bought a pair of M12s and his first impressions were quite positive. You might consider reaching out to him to compare notes. His channel is at https://www.youtube.com/@joeygsaudiochannel3972/videos
Ribbons still have a magnetic sound , so similar in tone to what most are inline with, ESL ‘s have a distinct unmistakable sound with very different Timbre , the lack of decay for tone is very evident in ESL’s ( the uninitiated calls this speed ) as well as its one size fits all for instruments..
Like everything in audio , if you like the qualities of a good esl nothing else will suffice ..
Ribbons especially Apogees have never had a magnetic sound whatever the hell that means... Electrostatics have never approached the sound quality of true ribbon loudspeakers. Might want to listen to some more true ribbon loudspeakers before you chime in.
I am a big fan of Final Audio. I have the M12+’s. I received them a few weeks ago and now they have ~150 hours on them and they sound in a word, TERRIFIC ! I have a modest listening space (10ft X 12ft) with the rear (behind my listening position) open into the kitchen area. I was impressed at first with the bass as they go to 48hz however sound robust right down to that area. They have opened up nicely in the ~150 hours and the mid-range and treble sound very transparent and fast. They take a good while to break in. The distributor says ~350 hours for full break in. I’m less than 1/2 way there and I can’t think they’d sound any better than they do now. I have mine paired with an SVS Micro3000 subwoofer which I crossover at 50hz with a 24db/octave slope and -15db volume and it meshes very well with the M12+’s. For most of my listening I really don’t need a subwoofer to fully enjoy the music.
Another thing that has impressed me is the subtle nuances in the music that I hadn’t heard prior. I keep saying, "well I hadn’t heard that before" ! Like for instance instrument decay lasting longer than I’ve ever heard it on my other speakers. Female vocals sound so real and with no sibilance. This was one of the best stereo equipment purchases I have made in nearly my whole life in "Audiophileville" (50+ years) If you have a small to normal size listening room, I believe the Model 12+’s would be just fine ! No need to go to the M15+’s or above, and I’d stick to the single panel ones as I don’t believe you’d need the models with the subwoofer unless you just want them integrated as a package. One more important thing... Ravi Velnati, the U.S distributor for Final Audio is a great representative of this product line. If you’re contemplating the purchase of one of their fine speakers, you should give him a call. More to come as these speakers get closer to the 350 hour break in.
Thanks ! They are in a word... Terrific ! I am using them with my LAiV GaNM's and they sound really good with plenty of power. I have the GaNM's VU-meters set for 0 to -50db range for greater meter sensitivity and they play at ~ -20db to-10db loudly. You don't need a gargantuan amp to drive these speakers. My Accuphase A48 stereo amp (90wpc 4-ohms) plays them at -10db peaks and that's loud ! The GaNMs sound really good, however I prefer my Accuphase A48 although it's quite a bit more costly. The difference isn't that much.
I'm glad you are enjoying the M12s and the LaiV GaNMs. Amplifiers make a difference but it is frequently quite subtle (assuming they can handle the impedance and power needs of the speakers they are driving). I'm glad I did my amplifier shootout but it isn't the first place I would spend a lot of money in a system.
With my recent purchase of the new Final model M12+'s, I've found they take some break in before really opening up. I have now ~ 150 hours on them and what a difference that many hours have made on the sound. Dynamics, subtle details, instrument decay, etc...
MRJAZZ asked the above question. I prefer my Accuphase A48 (90WPC class A amp not an integrated) sound over the LAiV GaNM mono's. While the difference is subtle but noticeable, what I'm hearing is a little more "body" in the music and more microdetail in general. Female vocals sound a little more realistic. The presentation just sounds a little smoother. I could be happy with both amplifiers but prefer the Accuphase A48.
I am very pleased that Paul has detailed his M35 journey. He is much more organized and articulate than I. Paul's experience
has mirrored mine. The M35 is creating beautiful music in my room powered by Threshold SA12e monoblocks and DH Labs
Q-10 cables. I prefer the M35 top end air provided by the SA12e 160 class A watts into 8 ohms. The Pass Labs 250.8
presents a softer, more recessed top end. Would love to try the M35 with the earlier design Pass Labs .5 or X series amps.
I have committed to the purchase of a CODA 16 amplifier at the recommendation of Final-Audio's Ravi Velnati.
With now 300-hours on my Final Model 12+'s, I can say they need the 350-hour recommended break-in time to sound the best. I have heard subtle but noticeable changes especially in the treble between 200 - 300 hours and while I don't expect much more in terms of sonic changes, it will be interesting to see if that proves true over the next 50-hours. I must say I'm impressed with the sound of these speakers in my modest listening space. I am considering the CODA Continuum-8 amplifier, along with the ModWright KMA99 mono's and the new Audio Research S-200. The U.S distributor Ravi Velnati highly recommends the CODA amplifiers and uses them with demo's and audio shows. I've heard them with the Final speakers, and they are accurate and powerful amps. And out of the three amps I mentioned before, the CODA Continuum-8 amp is the least expensive, I believe. Right now, I'm using my Accuphase A48 class-A stereo amp. It seems to have plenty of power (90WPC/4-ohms) especially in my modest listening space. However, I like having another amp for a possibly different sound and for backup.
Thanks Paul for the kind words and our phone conversation a few weeks ago. The Video was removed because of the lead time issue I'd mentioned and that @LiquidSound has reiterated here. I've chosen NOT to review the M12+'s in case I mention something not to the distributor's liking and have another Video on the M12+'s removed again. I've never yanked a Video off of my channel until now in over 6 years of it's existence !
