Alexia's vs Maxx3
Sins
1
Has anyone compared the sound between these two?
How does older speakers like the Watt Puppy8 compare to the Sophia3? It would be nice to hear from people that have some of the older iterations of speakers compare them to the new ones they may have heard in the showrooms.
Thanks for your consideration.
I've had W/P 7, MAXX 3 and Alexia's in my system. Just going by memory, but:
W/P 7 - these were my first Wilsons. All my previous experiences with Wilsons left me running for the door. Somewhere about the time of W/P 7 and the Sophia, the Wilson sound changed for the better. The speakers were more coherent and listenable. They were still using the Focal inverted dome tweeter, but it was more subdued. Still, extended listening sometimes gave me headaches, but the transparency and detail retrieval made them especially useful for mastering.
MAXX 3 - these sounded exactly like the W/P 7 with a more extended bottom end. The image height was raised about a foot and there was a larger than life soundstage. Tonal qualities were the same as the W/P 7, but the midrange was a little more rounded with more body.
Alexia - this is another totally different sound from Wilson. With the new silk dome tweeter and sharing the same mid as the XLF, you can literally listen to these for the rest of your life. Tonally, it's a different beast. Bass has better transient speed without losing body and tonal character. Mids are as sweet as if you are listening to them with the best SET's. The top end goes to infinity with no hint of compression or edginess. They are transparent enough to use for mastering but not fatiguing. This is how a speaker should sound.
+1.
I have now heard the Alexia's on a couple of occasions.I prefer them to all of the prior Wilson's with the old tweeter design. Like you say, they are a different beast.
"convergent synergy"
Wilson calls their silk dome "convergent synergy". Do they manufacturer this tweeter, or do they just brand it from an outside source?
Do they manufacturer any of their drivers, or are their drivers outsourced and built to their specifications?
Thank you in advance for your knowledge,
zz.
+1.
+2
