Is this by design or just an unavoidable problem due to battery charge necessity?
It applies to any appliance which interfaces to other appliances. It has less to do with battery charging, more with current/noise/conductive paths, filtering etc.
The whole is infinitely complex, unfortunately rather impactful on sound quality, and the reason for the existence of a large variety of audiophile ground tweaks.
This is largely unrelated to mains noise affecting sound quality in one way or another which you can indeed get largely rid of by using battery supplies. But there are even bigger advantages to using batteries, like the absence of rectifier noise and/or, depending on your design, no need for electrolytic bulk capacitors and filter stages which we consider to be large sources of "colouration (noise)".
Reactions: oldmustang
@Christiaan Punter will upload the current pricelist to our website's download section later today. We've held off on adding the Olympus to our website in an official capacity to limit the order volume.
Thank you Emile
It's so much better if they will go directly to the web page and discuss with Taiko Team not with us users.
But I must say without updated web page and no pricelist you already did quite a rumor anyways.
Congratulations
Never say never.
I was similar thinking long ago.
My totaldac 24 has NO output stage . Pure Vishay resistor ladder exits directly to XLRs and amps.
Internal volume control of totaldac must be very sophisticated as It was much better with Direct totaldac to amps than with respectable Kondo M1000 MK2 on the way.
So after 2 years of trying I sold Kondo becuse direct was simply way better.
Recently some friends were bringing many top preamps Including Audio Research , Gryphons , AudioNet and those always take some of the good stuff away.
I am still open to experiment and try new stuff. But so far direct is way better
Sure, we all have our individual preferences. Direct sound is great if you can stick to one digital streaming source. What if you are like me, and have several turntables, several CD/SACD players, cassette decks etc.? Even in digital I keep around a healthy diversity of products. Here is a great digital front end, the Chord Blu Mk2 transport and M-scaler and the Dave DAC on a lovely Chord stand with massive Wavestorm BNC cables. It has a rightness of sound on CDs that I find almost impossible to match via a streaming source. Rob Watts million tap filter technology does wonders in upscaling Redbook CDs, and I have many thousands of these lying around my house after collecting them for 40 years. CDs last forever. Hard drives? Ha! Don’t get me started. I have closets full of busted hard drives.
It has probably already been answered but here is my question… since the Olympus is all about minimizing processing steps has it been determined which file format is optimum? WAV is generally regarded (argued to be) the best sound format, does it hold true with Olympus? Is Olympus so good wav vs. flac is moot point?
Interestingly I marked my tests as inconclusive as it appears converting files can have an effect of its own. I had a small preference for the “untouched” file no matter the original format..
I was reading the Olympus manual and it is clearly stated few times that without the power cord batteries will be discharged completely after 30 minutes.
This suggests that ALL batteries MUST BE charged continuously during playback.
So one might think this is not battery powered equipment, as it looks like a hybrid power support.
Should that be corrected to specify exacly how long each of the battery pack will be able to keep power on in both Olympus and Olympus IO ?
Reactions: SwissTom
Hi Kris, Upon re-reading it, I can see why it may cause confusion. The 30-minute remark pertains to the System battery, not the XDMI battery. The XDMI section can actually be powered by the battery for up to 36 hours. But they are both powered from the same power inlet, meaning the server should still always remain connected to mains. This has now been further clarified and I will post an updated version of the manual shortly. Please find the updated information below.
Olympus Server BPS
The Server’s first battery section powers the core system. It is configured such that the battery is constantly charged, combining the technical advantages of battery power with the practical benefits of smaller cell sizes. When the server is in standby mode with fully charged batteries, the system batteries can hold a charge for up to 6 hours. But when the server is switched on and playing music, fully charged system batteries will only provide up to 30 minutes of charge. For this reason, it is recommended to always switch the server to standby before disconnecting it from the mains power and to make sure to always reconnect the server to the mains power as soon as possible after relocating it.
The Server’s second battery section powers the XDMI Output cards, and is configured to charge in cycles, like a traditional battery. The XDMI battery holds a charge for up to 36 hours, to provide more than enough pure battery power to cover the longest listening sessions.
Olympus I/O BPS
When the Olympus I/O is added, the Server’s second battery section is reconfigured to power the XDMI Interface cards that connect the Olympus to the I/O.
The Olympus I/O contains 2 battery power supplies and a custom power supply for charging the battery cells. The first battery section powers the Network Card, and the second section powers the XDMI Output. The batteries are configured to charge in cycles, like a traditional battery. They hold a charge for up to 36 hours, to provide more than enough pure battery power to cover the longest listening sessions.
Charge Cycle
To maintain ideal battery circumstances, there is a pre-programmed charging cycle between 00:00 and 07:00 for the Olympus Server’s second battery section and both the Olympus I/O’s sections. For these battery sections, the charging period may also be freely adjusted to precisely fit in with your personal schedule.
Olympus Server BPS
Olympus I/O BPS
Charge Cycle
Hey @Christiaan Punter - could you also add into the last sentence above, that the ‘auto’ charging cycle will only charge the batteries above the defined SOC level which by default is set at 80% in the BMS app. I thought mine wasn’t charging in the charging window until Emile pointed out that if it is already above the SOC level, it will not charge.
Thanks!
Olympus Server BPS
Olympus I/O BPS
Charge Cycle
Great Job !
Now it is perfectly clear.
Olympus + IO should be able to supply power from their battery packs for 36 hours
Except of the System battery power that is upto 30 minutes only.
Thanks!
Sure thing. I added this, and a few more clarifications, to both the Olympus Manual and the BMS App Guide. The updated versions can be found in the Downloads section on our website.
Yesterday, I had the good fortune to visit Steve Williams for my first listen to the Olympus/IO together with the new Horizon 360 Dac. The connection was with the XDMI digital card via the KBL EXTREMA cable. The listening room was also newly equipped with the Scherzinger Grid and EMI protection devices. I last heard Steve’s system in May with the Taiko Extreme and the original Horizon. My comments are based on these two systems. While the original Extreme/Horizon were top notch the Olympus/IO/Horizon 360 were quite a revelation. Overall, I would say the sound quality/presentation was 25% better with the new components. The bass was more articulate with greater impact. The sound stage was improved side to side and floor to ceiling. Dynamics, image and focus were all improved. There were many “performer in the room” moments. I can’t say to what extent these improvements were due to the Olympus or Horizon, but the synergy between the two was impressive. I can’t imagine anyone not being impressed with this combination….but there might be a few. I was not able to listen to the XDMI Analog card as Steve has his Olympus stacked on top of the IO preventing an “easy” switch of the cards. Perhaps this will be possible during the November audition. The build quality, fit and finish of the Olympus pieces were first class. These were more impressive in person than in the photos. Same holds true for the Horizon 360. The Olympus runs warm to the touch, so needs a bit of room over the top plate.
At the end of the session we switched the Scherzinger devices on and off running the same “Liberty” track. With the devices off there seemed to be less focus and detail. The difference wasn’t huge, but it was noticeable. These are on my list to explore further.
Steve, thank you very much for the visit and the opportunity to listen to your wonderful system again. Very impressive!
Under consideration for a “preamp” functionality version.
Dear Emile,
Do you expect the new preamp DAC version (hopefully with two digital inputs), expected for July-October/2025, to require an I/O Chassis? Or to fit in the Olympus without I/O?
In my view, if you made a super dupper preamp DAC, each channel using half of the I/O chassis, keeping the network card in the Olympus, possibly doing the pre-processing in the Olympus (like the MSB director) it would be great.
Cheers.
Dear Emile,
Cheers.
Hi @VPN ,
I really cannot tell you that yet. Naturally the I/O can be used creatively if we run out of space in the Olympus server, or for performance reasons.
Reactions: DW101 and VPN
@Taiko Audio
Hi Emile,
I hope you're doing well! :)
I understand that the output voltage of the Taiko XDMI-DAC daughterboard is 2Vrms (unbalanced, RCA).
Will the upcoming balanced (XLR) version have an output of 4Vrms?
Are you planning any additional changes, or will the two daughterboards be identical apart from the added connectors?
Cheers,
Thomas
@Taiko Audio
Hi Emile,
Cheers,
Thomas
Hi @SwissTom ,
Doing well, plowing through, thank you for asking :)
What is already becoming a bit obvious is that some systems benefit from lower gain where others perform better with higher gain, we’re actually considering to have a selectable gain. 2 or 3 steps perhaps to avoid mayor delays in the design.
Hi Emile,
Being forced to keep a keen “don’t go spending our retirement $$ on audio gear” budget, what would you consider a better sonic investment to include with an Olympus order — I/O or router/switch?
Hi Emile,
That's a good question.
They’re pretty competitive 1 on 1...
My decision would be based on the main music source you are currently using, or what you'd prefer to use going forward.
If you mainly use Tidal/Qobuz, absolute no brainer, the Router first, the DC-Distributor/Switch second, and perhaps a nice power supply. You could use a cheap NAS for music file storage then and recover some cash on ordering without internal storage.
If you mainly use your own files / internal storage I would go for the I/O as the benefit of the I/O is relatively larger if you use internal storage.
In general, if you value sound staging, both the Router and I/O significantly enhance staging, but ultimately the I/O pulls the best listening room walls vanishing act, which is why you read/hear more comments on crazy sound staging abilities of I/O owners.
