Which used 2nd tier SS Integrated to purchase
ssguy4ever
2
2
3
69
USA
I'm retired and like a lot of retirees I'm looking to simplify my set-up. I can't afford any of the 1st tier integrateds (such as Audionet Humboldt, Soulution 530, D'agostino Momentum, etc.) so I'm looking at those (SS) integrateds which would fall into the 2nd tier. My list has been narrowed down to 5: Audionet Watt; Soulution 330, Goldmund Telos Nextgen 2, D'Agostino Progression and Vitus SIA-025 Mk 2. I'm intrigued by the Mola Mola kaluga and the AAvik 1-580 but I still think class d is a work in progress. I could be wrong. The Gryphon Diablo 300 would be considered but I'm reading posts that it can be a little dark sounding. My speakers are, unfortunately, power hungry: 87 db and 4 ohms. I listen to Jazz, Electronic, Ambient, Classic rock, and classical (rarely). I'm looking for an integrated that excels with leading edge transients and bass extension and control. Please give me your thoughts and let me know if you've heard any of these and what you ended up with.
PS: Other factors: # of inputs (need at least 4 and would prefer 5. this leaves out the Boulder) and weight. Even if I could afford the price of the Humboldt my weak back wouldn't allow me to move it! thanks.
I'm retired too and I've just finished putting together my end game setups. I use a McIntosh integrated amp and a McIntosh amplifier, Conrad-Johnson for preamplifier.
Most people that I know are putting together massive systems for their retirement setup. I prefer a smaller setup, always have.
Are there any local shops in your area that carry any of your mentioned choices?
I've heard Soulution separates, but not any of their integrated amplifiers. Same for Boulder.
I like Soulution & Boulder products. Either would be a good choice from a sound point of view.
A local shop carries carries D'Agostino but I've not heard their stuff. The reviews are good though..
Like all other forums everyone will have their opinions as to what's best. However, only you can make the best choice for you.
Good luck and happy listening. :)
I think you mean Mola Mola Kula: https://www.mola-mola.nl/kula.php It has optional phono and DAC modules, which makes it very versatile. This model uses the latest Mola Mola amplifiers that are a step beyond the class D of yesteryear and you might find it sounds similar to class A/B (only your ears can be the judge, of course). It has plenty of power too. Worth a listen?
As you are probably know since you are interested in Audionet and Mola Mola, Bill at GTT Audio is the person to contact.
Not sure where 2nd tier begins and ends, but Accuphase, Lyngdorf, Nagra, etc. all seem to make a good integrated amp.
I just down sized, in terms of a smaller footprint.
I did not get a chance to try the Lyngdorf, but their TDAI 3400 seems intriguing.
No idea on your short list though.
Hello Sirs, I have listened to the gryphon diablo 333 and the top luxman amps driving the dali epikore in the same room and was very impressed. I don’t think the diablo sounds “dark” at all but very warm, musical and powerful.
You might need to consider pilium integrated amps too as they’re all in the same league and price range although the luxman is cheaper and more affordable unless you want to try their pre/pow combo which is also excellent.
Another option is karan acoustic, they’re incredible vfm and I would suggest you get the kam2000 monoblocks with a decent pre then you’re done. I was using them for around 10+ years and very happy with the results of them driving magico q5 speakers which are power hungry. The karans can give you everything you need at the same price with the others mentioned above.
Good luck with your search Sirs and I hope you’ll find your dream amps soon.
