Sorry see below GaryGajgmusic, how long have you had your 2i? Did you notice a break in for that? The DA2v2 took quite a while for it to fully break in.
Hi, just curious, can the DA2i built-in streamer be by-pass if you don't want to use it?Not sure if I misunderstanding you, but with a DA2i , you don’t need the NS 1. If you were asking how one box compares to two that’s a tough comparison because the 2i has a newer dac that is really quite remarkable, not the old one was bad
If you have a preferred streamer you can hook it up to any of the available inputs. You don’t have to use the built in streamer.Hi, just curious, can the DA2i built-in streamer be by-pass if you don't want to use it
Hi Andrew, thank you very much for the info. As I said earlier, I am just curious because I currently don't stream. I prefer to listen exclusively to recordings via SACDs.Why would you want to do that? The DA2i uses ConversDigital's newer CDM4140 module and has a direct internal I2S connection to the DA2i's DSP before D to A conversion. Whereas the NS1 uses the older ConversDigital CDMCM-2121R module, and has to go through 2 digital conversion stages before it gets into the DA2i DSP.
You can definitely bypass it with USB, I am not certain you could use another streamer. Hope that is what you were asking.Hi, just curious, can the DA2i built-in streamer be by-pass if you don't want to use it?
then i'm surprised you still have't gotten hold of the TX2 optical disc transport yet....
TX2 is much better than the TSDX.
there is a TX2 (with gold plating) somewhere on carousell.
Hi Jerome, I am very happy with the performance of the TSDX SACD transport and do not see the need to replace it with the more expensive TX2 for the following reasons: 1. The Esoteric drive in both is exactly the same. 2. Although the TX2 chassis maybe slightly better, for my case, I am using the very effective top-of-the line Ansuz Acoustics Darkz footers under the TSDX for resonance control.
For your circumstances, it is better but without the elaborate resonance control devices!I have both TX2 and TSDX in my home for more than 1 year.
TX2 audibly better.
Hi, I’m interested in your comment that the USB input of DA2V2 isn’t very good, as it is also my suspicion but am unable to prove. I’ve a Taiko Extreme server but have not been able to make it sound close to the TX2. Appreciate to know your experience. Thanks!the DA2v2 didn't have very good galvanic isolation for it's USB input
hopefully the i version have improved on this.
Hi Tony, to me and to many, it is not a surprise that an excellent transport would sound better than an excellent server.Hi, I’m interested in your comment that the USB input of DA2V2 isn’t very good, as it is also my suspicion but am unable to prove. I’ve a Taiko Extreme server but have not been able to make it sound close to the TX2. Appreciate to know your experience. Thanks!
The tiny black board, "CDM4140"can you identify whether is this a ConversDigital module, and if yes, what model is this?
Hi Tony, "The DA2i’s digital input system features enhanced isolation for USB and network interfaces, safeguarding your signal from external noise and interference. This ensures that your audio remains pristine, untouched by external factors."Hi, I’m interested in your comment that the USB input of DA2V2 isn’t very good, as it is also my suspicion but am unable to prove. I’ve a Taiko Extreme server but have not been able to make it sound close to the TX2. Appreciate to know your experience. Thanks!
