Shunyata Alpha and Sigma X new products, has anyone compared them to the V2's?
kimmusic
25
24
8
WA
I have 2 of the Sigma X QR power cables on order, but they have not shipped yet due to a parts shortage. The NR and XC power cables did ship to many dealers. Has anyone done a direct comparison of these with the previous V2 line? The new Alpha and Sigma X digital and speaker cables should be next.
I copied this I had posted from another basic cable forum, to move it to this Shunyata cable forum where it is more relevant to members.
I replaced an Alpha V2 NR on my DAC with a Sigma X NR, and felt there was a very good improvement. I think these Sigma X NR are worth considering for analog components like DAC's and pre-amps. The QR should be better for amps, but I still have not received those to try.
The Sigma X larger gauge wire might be more than is needed on low current, digital components, so possibly a Theta X NR or Alpha X NR might be more cost effective and get close to the same quality on them.
There is more detail with the X, possibly a little bright to me which may change over time as they settle in. It all really depends on the recording. Some poorly recorded music sounded worse to me with the X, but high-resolution files or better cd level recordings sound better. It reveals the music as recorded, and the soundstage can open up and the music dynamics can get real quick, as well as crystal clear, IF the recording is good.
The lower bass is simply amazing with Sigma X on my system and gets down to lower frequency levels you can feel, just below hearing that I did not get with the Alpha V2 on the same songs. Duets are much easier to hear both singers, and this is a very positive improvement.
Sigma X QR cables did arrive. So far, I hear a significant improvement on the amps, with better resolution of music recording details I had not heard before and improved soundstage. Dynamics are faster and there is an extremely quiet background, but I also have these plugged into an Everest, and that combo has worked best for me. There is some synergy in adding these cables to the Everest vs direct into the wall.
Now I am waiting to see if an Omega X AES or USB cable will be the next thing to consider when they are announced.
Reactions: Lee and MusicFellow
Wondering how long until they cycle out the current Omega cables...
Omega X power cords are in price lists now. Omega signal cables, I think, came much later than power cords so perhaps not due an imminent update ?
you mention a price list but I cannot locate one...Shunyata used to display USD prices on their web site but have removed them...are you referring to a dealer price list? It was so helpful to have the pricing displayed on the web site if simply to just get a sense of the range of pricing..
The Omega X QR are $12,500 and XC are $8000. Most dealers have them listed now.
Reactions: Lee
Hello what cables did you have in the amps before??
Thanks
I had Shunyata Sigma V2 before.
Reactions: Lee and j3brow
I just installed some Sigma X and Alpha X cables and really like what I am hearing but I will let them settle in before commenting.
Reactions: Ian B
we used the theta level entry cables at Florida Audio Expo along with the Alpha and Sigma power cords. This new stuff is an amazing value as they will compete with lots of products priced multiple times more IMO
Hi Elliot, I have Theta speaker cables and 1 pair of Theta XLR. I'm running direct from my QX-5 Twenty to amp. I only have 1 pair of XLR and want to really hear "Theta", and the QX-5 is pretty incredible direct anyway. What did you use Theta for at the show? Signal / speaker?
Other comments about the amount of detail from some X stuff are interesting. With some other wire, I've experienced what is almost "too much clarity", where the sound can go Dry. It creates discomfort. I have / have used Cardas Clear speaker / XLR, Clear Reflection XLR, Golden Reference XLR, Cardas Clear Cygnus speaker... Theta is different from each of those others, for me. Cardas Clear Cygnus, in particular, can sound pretty Dry in my system.
I'm actively comparing wire and I'm finding with Theta... I just forget about cables. Whatever is going on with Theta, it just sounds "right". It has strong bottom end and Ease... ease that you think won't be able to have the right amount of sparkle / detail...and then there it is... And it all just sounds "Right".
Hi, I used the theta balanced interconnects from the Wadax Studio player to the Riviera Preamp and from the preamp to the power amp along with the speaker cables. It was all Theta level product. The value of these IMO is extremely high and the sound was excellent. I am sure that Shunyata make some cables that surpass these but the price is really attractive and the performance is really excellent.
Best
E
Hi everyone,
Has anyone here had first-hand experience with the Sigma-X RCA? I recently ordered the Alpha-X after auditioning it and really liked what I heard. That said, I’m now considering moving up to the Sigma-X. The problem is, my local distributor doesn’t have any available for demo and no new stock at the moment, so I’d have to buy it blind.
Since the Sigma-X is about twice the price, I’d love to know what kind of improvements it actually brings over the Alpha. Most importantly, how does the tonality compare? Does the Sigma-X lean warmer, or is it on the brighter side? If it’s noticeably brighter—even if it outperforms in other areas—I’d probably have to pass.
Thanks!
I replaced an Alpha NR V2 on my Esoteric K-01XD with an Alpha-X. Observations:
1. Unexpectedly long break-in period - estimated 125 hrs - during which no improvement; system maybe even a tad sluggish.
2. Then the system bloomed. Deeper bass, meatier, more realistic tone, more detail, sound stage seemed to open up. Felt more like a significant component upgrade than a single cable upgrade. Impressive.
Reactions: kennyb123
I have still not had a chance to test a Sigma X QR, but I should be able to fund one this Autumn.
One thing on my mind is that I loaned one of my current Omega QR-s to a friend for some recording work, and at home using the stock Kimber Kable that came with EMM Labs DA2i reminds me of something I've experienced also with Cardas and Transparent PCs: rich and and natural tone with greater bite and speed, especially in the midrange, if less resolution and soundstage. Those copper cables always seem less analytical, and have a musical and colorful glow.
I think crucial to me is if the X line has improved the tone color and natural qualities over previous Omega. I've always been impressed by my Shunyata cabling at each stage, but I do start to feel like I'm now missing some richness and color. I'd prioritize that over greater noise reduction.
I remember my Sigma NR v2s taking 3 weeks...My Omega XLR cables literally took almost two MONTHS do go from lean and bright to dark and relaxed. I think it's in part the silver that they are using now.
