From the Taiko Olympus Manual, page 15What are the two ground posts on the back grounding? Chassis and XDMI card?
Grounding posts
Grounding is not required or recommended but to facilitate certain use cases, there are 2 binding posts for grounding purposes. Looking at the back, the left grounding post grounds the chassis which floats by default. The right binding post connects to the charger AC-DC power supply, which is grounded through the IEC inlet ground pin as well, which is a safety requirement, but the entire AC/DC charger supply does not connect to the rest of the Olympus chassis, it truly floats.
There is also a post or two from Emile in this thread that says essentially the same thing. You can find it with the Search function at the top of the WBF page.
Steve Z
