At least it can be performed by the dealer so no need to send the DACs back to Cyprus.I wouldn’t have an issue with this and it seems pretty straightforward but a lot of people are not comfortable doing stuff like that.
My question is simply this: Why has my TaikoAaudio network, which was stable as a rock for months, decide to go bizerk and shut down intermittently only since I installed TestFLight 2.4.7.1? This has still not been addressed after several days while making sure that the Taiko Audio network is active (unless it drops in the middle of the night) and my TV passwords kept current and refreshed for the team to see anytime. I am readily available by email, phone, morse code, smoke signals, and carrier pigeon but....crickets. Very frustrating. If I knew how to change the router channel, I would, or do anything else required at my end. I don't need my XDMS playlists (even though I put work into them) since the Olympus will use Roon. But is a stable TaikoAudio network with Roon only too much to ask?
How's the Olympus production line going ? first shipment batch close ?Just a few more Olympus sales away![]()
Have you considered buying a guitar? Makes sound reliably. An acoustic guitar.These network issues do not sound good! Hence me delaying my order until "thought" things were stable. Not a good situation...
Yes like in Animal House when Belushi smashed it!Have you considered buying a guitar? Makes sound reliably. An acoustic guitar.
Even then it will make sound reliably, if not well.Yes like in Animal House when Belushi smashed it!
So are you saying keep the corkscrew away from sensitive network gear?Even then it will make sound reliably, if not well.
However, similar treatment of your network equipment may result in connectivity issues.
Make wise equipment choices based on your expectations, environment, and beer and donut consumption.
But its OK to post Cherry Blossom pictures in the thread as well as NBA basketball posts (which you conveniently removed) that have nothing to do with the Olympus thread????I think you would get better answers through the alpha users group on the Taikp channel at Discord or to submit a ticket direct to support@taikoaudio.com
This has nothing to do with the Olympus thread
Best to keep that away from all sensitive areas. Power outlets too.So are you saying keep the corkscrew away from sensitive network gear?
Just curious about the charging time setting. If Olympus needs to be charged all the time while playing music, what is the point of setting the charging time for it?Dear all, we just finished the BMS App Manual!
The Battery Management System (BMS) App is your main gateway to the Olympus Music Server’s charging circuits. Communicating directly with the server via Bluetooth, it requires no network skills and provides an easy and reliable method to connect to the server and configure its settings.
The manual can be found on the downloads page of the Taiko website:
A Music Library Migration Guide and Olympus manual are also in the works and to be released next.
There are 2 separate BPSs, one charging all the time, the other can be managed by the app. I think.Just curious about the charging time setting. If Olympus needs to be charged all the time while playing music, what is the point of setting the charging time for it?
Is it still charging when powering off?
Do you have any theories as to why using the Taiko router wifi would sound better than using one's home wifi + port forwarding?
