My library is bigger than yours
The reality to all of this may very well boil down to the fact that streaming is indistinguishable from internal library and if indeed we find that to be the case our library might be used only infrequently. To my ears now using XDMS-NSM I find it almost impossible to audibly discern the difference in formats when I stream native. Bottom line therefore is that with Olympus and XDMI Emile promises it to be even better. So streaming might be all we need
The 224+ is 30 watts...
Where are you seeing that? Their specs say under 15W in typical use. That is just above a 1.25A since it runs at 12V.
Reactions: John T
I'm hoping and betting that the Taiko team will prepare a summary set of "recommended best practices" ranked by order of sonic importance ("must have" to "nice to have") for the more common configurations of the Olympus system installation including storage and connectivity options. ;)
That will in fact be great. But I have custom files from Harry Weisfeld, Philip O'Hanlon, other obscure albums/tracks. I would love to just stream without any of this other stuff...
This information was given to me from a Synology Rep. I'm looking now, I suspect your info is more accurate...
Your correct David, I see quite clearly 15W at full usage. I know better to just take info without double checking!
Reactions: dminches
My Sean Jacobs LPS is about 3A. I don’t think it could power a 2.5A NAS plus the switch and router. It would be close!
It is a great low powered NAS that can hold a very large library if you are fine with RAID0.
Reactions: John T
My new NAS setup, preparing for the Olympus:
- Existing Plixir Statement PS, 6A 12V = 72W + Taiko DCD
- Synology DS923+ (4 bay, 35,5 W - I suppose if using HDD, not SSDs) running in silent mode.
- 2x Samsung PM893 2.5" 7.68 TB SSD (completely quiet). Space for two more SSDs if necessary.
- Additional 4GB Synology memory
- 1TB NVMe Read Cache
- Synology 10Gbe module (to be used at 1Gb with Taiko Router, but better than original port).
The 10Gb port (running at 1Gb) will be connected to the Taiko Router, feeding audio to the Olympus, and the regular 1Gb port will be connected to the upstream top quality switch to feed dowloaded video to the appletv X. The NAS will have both music and video, which will never be used simultaneously.
Reactions: Alex G
Taiko router is 500 mA
Taiko switch is 100 mA
If your NAS is 2.5A it is probably at max consumption when it is booting.
Normally it will probably drawn constantly about 1.5A if you use SSDs.
So it should be just OK.
Alternative is what I did
I got a SECOND DCD.
Having 2 of them is a fantastic addition to the system as I can power the modem and home router out of the second DCD.
Reactions: DW101
Another possibility that crossed my mind is that the USB input on the A/C DAC uses a small plug-in PCB that appears could be easily swapped out in the field. Maybe that is the plan to swap it out with an XDMI receiver board that is powered by the said external powered box? Keeping an end-to-end XDMI solution.
You are the second person who speculates that this is the solution, changing the PCB, USB at the AC input for an XDMI PCB and frankly I think you are both probably right.
The blue PCB looks quite accessible.
Reactions: aLLeARS
Emile
Just wondering if you could confirm the digital outputs from XDMI
You mentioned it will be possible to incorporate the AES, Spidf at RCA and BNC
Are all 3 there ?
I am asking as RCA is usually 50 ohm
BNC (a true Spidf) is 75 ohm.
Exactly. Remove the two screws holding it in place and it will simply unplug from the lower (I2S?) board. Also would explain the use of an external box that has its own power supply. For powering the XDMI input board. Actually, would be a very clever way to make the upgrade for Olympus owners without having to ship these uber heavy DACs back to Cyprus.
Incidentally, who else has made this prediction?
Well, since his assumption was in a private message, I don't know if it would be correct for him to give his name. Of course he is someone much more technically qualified than me and according to him the red PCB is the reclocker, the blue one is the USB receiver and the conversion to I2S takes place there.
Reactions: aLLeARS and wil
It's fine :)
@nenon if we are correct this will be a great solution and I would place an order as soon as it becomes available. I have no doubt that the XDMI interface will be sonically superior to USB. Taking the A/C DAC to another level.
If the suggested solution is correct (replacing USB board) most A/C DAC owners would need assistance in performing the swap.
Aries Cerat use the USB receiver from JLsounds:
These blue boards seem to be plugged into the reclocking board and not soldered so it should be easy to remove the USB board and replace it by something like an XDMI receiver board.
I think this task can be performed without assistance.
Aries Cerat use the USB reveiver from JLsounds:
I wouldn’t have an issue with this and it seems pretty straightforward but a lot of people are not comfortable doing stuff like that.
