Hi Roysen:
>When it was released it was an all-out assault on what could be done to make a preamplifier sound as good as possible.
True. OTOH, once a design has been put into production, the designer doesn't stop having new ideas. The 3.0 represented an extreme expression of one possible approach to preamplifier design. The 4.x family represented a somewhat different approach to preamplifier design, which in my opinion is no less valid than the 3.0's.
>Up until today it must be Lyra Connoisseur's most ambitious product development.
If you include chassis build and power supply extravagance, yes. But machined-from-solid chasses and giant power supplies are not the only path to convincing sound quality.
>This preamplifier is very rare and only made for the Japanese and maybe also the American markets.
The 3.0 was built using a more fragile method of air-dielectric construction than the earlier 2.x, or the later 4.x and 5.0. We brought one of the final prototypes of the 3.0 to the US for an audio show, but that experience made it clear that shipping the 3.0 overseas would likely result in a high rate of breakage and failure (DOA). For the same reason, the 3.0 was only sold in Japan, and it was only delivered to dealers by car and hand. No freight companies were used to deliver 3.0s, even within Japan.
AFAIR, the preamps that Roy Gregory (and Chris Thomas) used as their references were first the earlier 4.0, and then the later 4-2 and 4-2SE.
Regarding sonic differences, the 3.0 was a very bold and dynamic-sounding preamp that also had quite good resolution for its time. The 4.0 was not quite as dynamic-sounding as the 3.0, but even the early versions had better timbal and spatial resolution than the 3.0. The 4-2 was not sold in Japan, but a simplified version of the design was sold in Japan as the 4.0 Advance. The 4-2 had considerably better timbal and spatial resolution than the 4.0, and dynamic resolution was improved as well (although in terms of dynamic "clout" the 3.0 still retained some advantages). The 4-2SE was likewise not sold in Japan, and no corresponding Japanese version was ever made (not even in simplified form). To my ears, this surpasses the 3.0 in nearly every way, including dynamic range and transient impact.
Over the past year, I have been quietly working on a new version, which may or may not be released as a product (I may choose to provide the boards only for rebuilds and upgrades to existing 4.x preamps).
>I think the Connoisseur preamplifiers might have been designed by three different designers from three different companies.
No, there have only been two designers. At first it was Petr Mares, and then starting from the 2.5 (which was not released as a product), Jonathan Carr (me) became involved in the design process.
I first met Petr in 1987 or 1988, and when I visited his home, he had a prototype of an air-dielectric phono stage, which he was using with a Well-Tempered turntable and one of my cartridge designs. I thought that the sound was amazing, and I felt that I had to make more people know about Petr's work. I begged Petr to sell me that prototype, to which he graciously agreed, and I brought it back to Japan as carry-on luggage (pre 9-11 days, you know). I played Petr's prototype for my friend Stig Bjorge, who was the owner of an audio company called ScanTech, and he concurred that it was very special. So I wrote back to Petr and encouraged him to put the phono stage prototype into production, which he did. Petr formed a company called Connoisseur (no Definitions yet) to do so, and ScanTech started importing these into Japan and distributing them.,
At first they achieved a cult-following, but gradually they become known to a wider audience, and ScanTech needed more phono preamps. But the 1.0 was totally air-dielectric - it didn't even have normal circuit boards. Petr used blank copper-clad board material, which he would score into copper squares and strips, punch holes at strategic locations for turret lugs, and build into a 3-D maze-like structure, to which he soldered the transistors, resistors, capacitors et al. Around the same time Petr got married, so he found it increasingly difficult to allocate the time to build the preamps that we were asking for.
More after I take a breather! jonathan
Hi Roysen:
Part 2
PS. Please let me know if anyone wants to hear about the 4.x and the 5.
Absolutely fascinating material, Jonathon, thanks for sharing! This sounds like a variation on the so-called Manhattan style of construction for RF, something I came across some time ago. And something I put in the back pocket to try one day ...At the same time, I was working on the circuit board designs, first to engineer out the mechanical inconsistencies that the 2.0 amplifier boards and transistor modules had, and next to get Petr's voltage regulators working. I had selected some fancy high-frequency ceramic-loaded circuit-board material which had good electrical properties, but it turned out to be mechanically and chemically rather weak. I drilled holes in the amplifier boards and inserted teflon standoffs to create the mounting points for the air-dielectric, but in practice the bonding of the standoffs to the circuit board was not nearly as secure as I would have liked. This was a key reason why I later vetoed exports of the 3.0.
Thanks Jonathan for setting the history straight! I am very satisfied with the 3.0 and will not replace it unless there is another product from a resurrected Lyra Connoisseur which would be as similarily in a class of its own as the 3.0 was when it was introduced...I really hope you will be able to resurrect Lyra Connoisseur. Thanks, Roy
