Also, does this new Olympus Server have its own clock which then feeds into the DAC? The Zanden DAC takes it clock feed from the Zanden transport as part of the i2s connection.
Yes it has its own clock but it can also accept an external clock (necessary for MSB Pro ISL for example). For custom I2s applications we can probably design something which can both accept external clock as provide its own clock.
When I drew this diagram, which was then added to the documentation, Emile hadn't mentioned the problem of slot 4 having to remain free for ventilation.
This diagram remains correct if, and only if, we don't plan to use the XDMI/DAC or opt for an Olympus Server configuration with no storage space.
But as it is the diagram may lead to some confusion...
There is a lot going on and a lot of moving parts to the Olympus. In an earlier post Emile answers a question (actually, posed by you!) about using USB and the slot 4 heating "problem".
Hi Thomas. I think you're correct but I seem to remember Emile with his schematics making his case and showing what XDMI does and asked everyone why ever use USB when you have XDMI. My plan is to only use XDMI native
Well noted! I've been absent from WBF for a while to focus on Support via other channels but I'm in the process of updating the Olympus documentation as we speak.
About 60 watts during normal use, in a user configurable 6 hour window this increases to 90 watts. If you leave it unpowered for a longer period of time it will use 120 watts to recharge for 4-6 hours.
Do you experience the SQ impacts from being unpowered like in the Extreme? The common wisdom is that an Extreme takes a full week to get fully back on song after being powered down. What is the case for the Olympus (a for the I/O)?
Hi Emile, if I use Olympus XDMI AES output to my Vivald upsampler, DAC and clock, will my clock still work and lock to my upsampler and DAC without locking to Olympus? With extreme USB output, it’s working. However, I am not sure if it will work with XDMI AES.
I'm obviously not Emile and I don't have an Olympus (yet) but I have a dCS Vivaldi DAC and Clock and used to have an Upsampler. If you have the dCS Clock connected and you've selected the dCS clock as the clock source in the settings for Upsampler and DAC, that is where it will stay. The equipment will not "auto-sense" or otherwise use some other clock signal from a source, even if that other clock signal is present.
If one goes on a vacation for a couple of weeks and would shut-down the system completely: Would that „hurt“ the battery longevity? Would it be recommended to recharge the batteries fully before unplugging or are do they not care if charged or fully depleted?
No. But they’ll be fully depleted when you return. UNLESS you use the remote app to put them in “shipping mode”, which disables both the in and output, then the batteries will keep their charge indefinitely. I guess we could add a “Vacation mode” menu option but that will then do exactly the same as “shipping mode”.
If you just let it run unpowered / deplete the batteries, you will need to let it recharge for a couple of hours before you can use it again. 1-2 hours before you can boot, about 6 hours for full SQ.
Well beside the galvanic isolation by means of batteries its also triple regulated and has 5 filtration stages. Although 100% immunity does not exist its about as immune as it gets, let’s call it 98%
This is one of the most important things to me. Bad power impacts very significantly my listening pleasure. Midnight is the best time to go and listen.
Also are the components powered together isolated (filtered) from each other?
Like those 2 pci express cards in the main Olympus being on one battery could be filtered from interfering each other by using your technology from the DC distributor.
And they could have a separate voltage regulators.
Just curious how this is optimized.
