OK, here the situation. I have never owned a stand-alone sub, as all my speakers have offered very good and deep bass without the need for them. With the exception of my ATC50 Actives (with a single 9” bass driver), all my speakers in the last 30+ years have had twin 10” or twin 12” bass drivers. Earlier ones (from the 1960s) had single 15” drivers.
So here are my questions, prompted by claims that adding subs will significantly improve the quality of bass by filling in or neutralising anomalies in the sound that reaches my ears, as a result of room features. Incidentally the room – see rough plan attached – has already been worked on to achieve a good sound with partial carpeting, curtains, soft furnishings, etc as well as very careful speaker setting up.
1. Do my Avantgarde Duo XD speakers with their twin 12” drivers, need subs at all to improve sound quality or to smooth the bass response? I suspect many will say Yes.
2. If so, do I need these subs to have 12” or larger drivers? I’m hoping that smaller subs, perhaps with 10” drivers will do the job just as well, as I don’t need deeper bass, just smoother
3. How many subs should I be looking to add? I’m told that at least 2 is the likely answer, but my new preamp (if I get the NAD M66) has outputs for up to 4 subs, all of which can be DSP’d by Dirac Live and / or Dirac Live Bass Control.
4. I don’t want signal cables trailing across the floor to these subs. Can I run subs equally well wirelessly? If so what (preferably XLR – XLR) transmitter / receiver devices would do the job. I’m not concerned about power cables as power can be found locally. Or I could use subs that already have a wireless feature, but of course I don’t want to compromise on quality.
5. The big question – which subs should I go for and how many? Good quality without having daft prices.
6. The equally big question - where should I place them? Main options, marked in green on the plan with a number or a letter, are where subs could be placed. Subs in positions B, 3 and 4 could be hard-wired to the preamp using XLR interconnects.
Your expert knowledge of all things sub and your imagination would be greatly appreciated.
A challenge I hope you may enjoy!
Thanks. Peter
