Is the KBL cable stupid money or somewhat rationally priced?So far there are two options…..a cable made by Lukasz and one made by a Polish company KBL which Lukasz lauds
It's all been posted by Lukasz. His cable is $1000 USD and the KBL is $3000 USDIs the KBL cable stupid money or somewhat rationally priced?
Mercifully, not Wadax wire pricingIt's all been posted by Lukasz. His cable is $1000 USD and the KBL is $3000 USD
...It is more than a job to them but rather a ...DEVOTED PASSIONreports Im getting out of Munich from vendors who happened to be in Emile and Bob's room is that the sound was nothing short of spectacular. And this is from XDMI coming via the analogue card.....streaming only with no internal files. To me that speaks volumes. Kudos Taiko team
It was refreshing to see the entire Taiko team enjoying beer and schnitzel after a hard but rewarding day's work. The synergy of the Taiko team is written on each of their faces by their smiles. One can sense that this Taiko team enjoys everything they are doing as it is more than a job to them but rather a career
@Taiko Audio
Hi Emile,
I hope all goes well in Munich and that the Olympus-XDMI gets the attention it deserves.
Apart from being a show for consumers, I can imagine that Munich Audio is also an opportunity to make contacts between audio professionals.
Have you approached or been approached by manufacturers curious about or interested in implementing the XDMI interface in their products?
Cheers,
Thomas
StavrosHi from the AC room
Would be nice to clear things up a bit.
On our pre show tests, we found the Xdmi aes not as good as the USB port,so we went with usb connection.
For any reasons that may be ,USB sounded fantastic over the AES.
Funny to hear we would scrap a massive efford setting this system by sabotaging our digital that played 50% of the time.I thought this forum was adults only ?
Best regards
Stavros
It is on the Lampizator Horizon and Totaldac
The thing to remember is how these interfaces are implemented in the DAC.
I wrote about this earlier in the thread, there are some very distinct differences between these interfaces beside practical things like sample rate support.
With AES/EBU and SPDIF the clock is at the source and embedded into the datastream send over the cable. This is then extracted at the receiver, in short, clock jitter will be relatively high.
To address this problem DAC manufacturers can incorporate reclockers on their inputs. Some DACs accept an external clock source, allowing you to use an external masterclock.
A very obvious example is Totaldac, their larger model DACs come with a reclocker by default, you can buy the reclocker seperately to add it to lower priced DACs, some of our customers even use 2 or 3 of these reclockers in series.
With USB I2S is generated inside the DAC, including clock, it’s up to the manufacturer how to further implement this, for which there are multiple options, but obviously jitter can be low to start out with. BUT USB receivers are electrically noisy.
Stavros tells me he optimised his DACs for USB, and yes to my ears it does sound better then AES/EBU, although AES/EBU is smoother, it doesn’t really capture things right in the time domain, as in sounds a bit slow / unexciting. So next up a native implementation for AC dacs!
All good.thank youStavros
That was my fault.. My apologies..
Marc
Although I never tried the AES input on my Kassandra, since in AC you recommended me to go with USB, I thought that the XDMI output on Olympus and the input on the AC DAC with double reclocking in AES, would make a difference. The results you have obtained, Stavros, make me rethink my Olympus purchasing strategy: buy the XDMI card now, or wait for AC to implement XDMI.Hi from the AC room
Best regards
Stavros
Very happy to hear about that, thank you!View attachment 130887
We had a productive meeting with Daniel and Jonathan today, it was very nice to finally meet face to face. @DMSB will post an update on our adaptation of the MSB Pro ISL technology in the next week or so.
Did you talk to Stavros about the XDMI implementation?
Great information. On the other hand, I don't forget that you said that when you designed the balanced analog output, you would take the opportunity to add some “treat” to the current RCA output.
Emile.The real question everyone will ask here is
if we will get fully battery powered Olympus? Or the 3 Battery + AC powered as designed before ?
That should be additional significant upgrade in SQ.
Also will that require additional patience?
There’s only one Olympus, and yes it’s fully battery powered. Will share in depth details when I get a chance.Emile.
Sorry for bothering after a very busy time in Munich. I believe this above was not answered.
I hope there is still a chance for fully battery supply Olympus to be implemented into my Olympus.
I know it's a longer story of how you did it
but having it build in would be probably an ultimate solution to the power problems I have.
