Both are the same product.- Kondo SFZ MC
- Audio Note Japan
It's the replica of the above.- Audio Note UK
Very good sounding SUT from Germany.- Consolodated Audio
I’ve heard good things about thisPhasemation T-2000.
Phasemation
We hope to make use of this high technology in a field of art and culture, and aim to develop and produce the audio equipment steps into the technological practice and reproduction of music that the existing ones have not achieved. We have started up Phasemation as an audio brand.www.phasemation.com
Not exactly true and as always the devil is in the detail.Both are the same product.
You can't go wrong with any of them. All (Kondo, AN UK, Consolidated Audio) are very good sounding SUTs but I prefer Kondo SFz.
Will take a look thanksReally good sound![]()
Step-up transformer SUT-1L | MK Analogue
Highend MC transformer for low impedance pickups up to 10 Ohm internal resistance – fully balanced – no hum or other interferencemk-analogue.com
It would be nice to set up, unfortunately my pockets aren’t deep enough to purchase all I’m afraid.There was a shoot out in the U.K. with AN S8 and Slagle silver. I wasn’t there but the guys found out close and one guy bought the Slagle silver. I heard his system with the AN IO gold sounds incredibly good.
anyway if you get all these SUTs please let me know and I will fly over to help in the shootout.
Hi,@Bling23 i used the Auditorium T2 with a Denon 103 cart and it was great and more budget.
I've used AN MC carts (iO1 and iOGold) with S3, S4 and S9. I think the AN SUTs are amazing but of course they cost alot and are only any good with AN carts (I couldn't find other brand carts that had similarly low output).
I found my S4 second hand for about $4k aud - i think they retail for close to $12k AUD.
the s4 compared to the s3 was 100% worth it. a sound that is natively pleasing. plus resolution and dynamics etc. magical. i've heard the s9 for limited periods and it is fantastic.
Thanks for that I was actually looking at all of those , the SFZ is meant to be really good on lvl like AN 8 or 9 and I’ve read the Consolidated audio is very good value. I know you run different carts with them but how would you describe their sound differences likes or dislikes I would be really interested to know your thoughts. ThanksI am using 1:10 Consolidated Audio for High Imp carts, like Soundsmith or vdh.
For low Imp carts, like MSL and derivatives I prefer Kondo SFZ.
For all others, like Koetsu, Etsuro and more I prefer T -2000.
your decision should be very much cartridge driven
The Kondo SFZ (I am using the first generation of SFZ) is better in all regards, but on the other hand a lot more expensive tooHi Jürgen,
and how do you like the high impedance input of the Kondo SFz with higher impedance cartridges in comparison to the 1:10 Consolidated?
Good morning shakti I'm bothering you again. for loading my msl Platinum Signature. I currently use a Ypisilon MC 10 L transformer with my allnic 7000v phono preamp with kR or gec u 52 rectifier valve. I did some tests with the internal step ups of the phono preamp or with the allnic aut 8000 step up. I'm tempted to buy the MSL 1030 which is different from the Ypsilon (10X I read a 470 ohms load) or the Allnic 8000 (13X 22db I read a 270 ohms load) it would give me a gain of 26 db with an impedance of 470 ohms. You who have tried everything, would you take this step? I currently prefer the ypsilon over the other options. Next week I will be in Paris and I would like to go and see François and I could probably find some other alternatives there. Apart from the kondo which costs a fortune and the EMI which to get it to Italy, the copper version with the customs involved would cost the same as the silver one, what would you recommend?Il Kondo SFZ (sto usando la prima generazione di SFZ) è migliore sotto tutti gli aspetti, ma d'altra parte è anche molto
The MSL 1030 works very nicely with the Plat Sig. That’s what I strongly preferred over my Ypsilon SUT. Also, Sound Tradition MC 907 is a great match for that cart.Good morning shakti I'm bothering you again. for loading my msl Platinum Signature. I currently use a Ypisilon MC 10 L transformer with my allnic 7000v phono preamp with kR or gec u 52 rectifier valve. I did some tests with the internal step ups of the phono preamp or with the allnic aut 8000 step up. I'm tempted to buy the MSL 1030 which is different from the Ypsilon (10X I read a 470 ohms load) or the Allnic 8000 (13X 22db I read a 270 ohms load) it would give me a gain of 26 db with an impedance of 470 ohms. You who have tried everything, would you take this step? I currently prefer the ypsilon over the other options. Next week I will be in Paris and I would like to go and see François and I could probably find some other alternatives there. Apart from the kondo which costs a fortune and the EMI which to get it to Italy, the copper version with the customs involved would cost the same as the silver one, what would you recommend?
