Thankyou for asking this question. I just recently purchased network card, router and switch.
Check posts :
#89
#114
Hope it helps.
Thanks ED. XDMI ASIO client means that digital output AES/EBU, RCA of the XDMI can still play by XDMS-NSM?XDMS - NSM is ASIO only
So XDMS - NSM can deliver data to any ASIO USB Driver, and also XDMI ASIO client
An audiophile marches on his stomach.You forgot the waffle card.
Indeed. XDMI works with Roon and XDMS-NSM, and for both local and streaming music sources.Thanks ED. XDMI ASIO client means that digital output AES/EBU, RCA of the XDMI can still play by XDMS-NSM?
XDMS-NSM works with an ASIO USB driver and with the XDMI ASIO client. This means that Olympus USB, AES/EBU, S/PDIF, and Analog all can use XDMS-NSM. The Wadax Atlantis Reference and Arcadia are on the supported DAC list.Ed, does this mean that I will not be able to hear xdms/nsm on my wadax atlantis DAC, and only xdms by way of aes/ebu; and I can only hear xdms/nsm directly over RCA cables direct to my preamp?
Thanks! - kevin
According to the document on Taiko HP:Question 2:
What powers what?
Again in the context of Olympus Server + Olympus I/O, is the following correct?
BPS – Olympus Server
• 1x BPS powering the OS and the music drives
• 1x BPS powering the first set of the Interface Cards
• 1x BPS powering the second set of the Interface Cards
BPS – Olympus I/O
• 1x BPS powering the Network Card
• 1x BPS powering Audio Output Cards
Hi Thomas,What powers the QSFP cards in the I/O?
Hi Thomas,
my understanding is that they are powered from the Olympus server.
Again I understand this reads as complete gibberish to many, especially those less versed in computing technologies, it will become much clearer when this actually starts arriving, it's only complicated if you try to understand it without an actual hands-on experience, I think![]()
Hi Emile, if the Olympus is used continuously during the charging phase when the batteries are low , how are the 5 power supplies utilised then ?Hi @SwissTom , very much appreciate your help in painting an as clear as possible picture.
As we are launching a series of new technologies all packed together in 2 main products it can easily become confusing to the point where it's easy to mix up aspects from individual parts.
Let me therefor start with listing the individual new components / technologies:
1) The Olympus Server utilises the latest available computer hardware with the following differences to the Extreme:
-The Extreme has 2 Intel Xeon Scalable processors with 10 CPU physical CPU cores each for total of 20 physical CPU cores (40 virtual), 48Gb DDR4-2400 Memory, PCIe gen3 interfaces, uses PCIe gen3 M.2 music storage drives and runs Windows 10
- The Olympus has 1 AMD Epyc 4th gen processor with 4*8 physical CPU cores for a total of 32 physical CPU cores (64 virtual), 128Gb DDR5-4800 Memory, PCIe gen5 interfaces, uses MCIO (PCIe) gen5 U.2/U.3 music storage drives and runs Windows 11
2) We are launching new power supply technologies, both linear as battery powered, both are highly power conversion efficient (90% +) and very low noise / transparent, made possible by utilising modern GaN fet technology with our own "twists".
3) We are also launching a new external interface solution utilising high speed (aggregated 112Gbs) QFSP28 cables, this enables the Olympus I/O product. In a nutshell this allows PCIe cards to be placed in an external chassis without the usual drawbacks of such a solution, it even improves performance rather then deteriorating it.
4) Last but not least we are launching our new XDMI music interface. XDMI has an ASIO driver as input, which you can use directly as an output from either Roon or XDMS playback software. This ASIO driver then directly transports the audio bitstream to the XDMI baseboard, over PCIe, where it is converted to I2S, bypassing multiple stages of processing and conversions which are inherent to other protocols. This as as direct a conversion as possible. The XDMI baseboard lastly has a connector which allows connecting the optional output boards, which can either generate a direct analogue output by means of a DAC, or a variety of digital outputs.
From a practical point of view:
The Olympus server has 4 PCIe slots in which you can mount interface cards.
The Olympus I/O has 2 PCIe slots in which you can mount interface cards.
The Olympus server contains 2 Linear Gan Fet based power supplies and 3 Gan Fet based battery power supplies.
The Olympus I/O contains 1 Linear Gan Fet based power supplies and 2 Gan Fet based battery power supplies.
The Olympus server 5 power supplies are utilised in this way:
1 Linear power supply powers the motherboard/CPU
1 Linear power supply is a battery charger
1 Battery power supply powers the storage drives
1 Battery power supply powers the network interface card
1 Battery power supply powers the output cards (USB and/or XDMI)
The Olympus I/O 3 power supplies are utilised in this way:
1 Battery power supply powers the network interface card + the external interface solution PCIe card
1 Battery power supply powers the output cards (USB or XDMI) + the external interface solution PCIe card
The Olympus server + Olympus I/O stack 8 power supplies are utilised in this way:
On the Olympus server side:
2 Battery power supplies power the external interface solution PCIe cards connecting to the Olympus I/O
On the Olympus I/O side:
In case this is still unclear, which is completely understandable:
The Olympus server can provide BOTH USB and XDMI as it has enough PCIe expansion slots (4), where the Olympus I/O has 2 PCIe expansion slots and therefor you will have to choose between USB and XDMI, as the other PCIe expansion slot is occupied by the network card.
@Taiko Audio
In the context of Olympus Server + Olympus I/O, is the following configuration possible?
