Sonorus ATR10 reel-to-reel tape deck
19,474
17,410
3,530
I believe the Sonorus machines come from Arian Jansen. I was quite impressed by one of his machines a few years ago, when I heard one that Philip O'Handlon had. Not sure if it was this same model. He essential builds a new machine using some key Studer parts. Larry
Philip is the Distributor I thought. I heard it at Philips house and met Arian there. It has a wired remote
So would those Studer parts be new (old stock) parts? If that is the case, wouldn't this be the first wholly new R2R on the market, since the others that I am aware of are all re-builds (yes, significant with massive modifications) of existing decks such as Technics? I personally don't count the Studer parts as discounting this from being a brand new from the ground up deck if that is the case - since if you take high end CD players, for example, they are going to use all sorts of third party parts including the transport itself, for example (e.g dCS).
PS: I like the fact that the deck comes already with some "audiophile" tweaks, such as the silicon rings around the valves. It really looks nice inside - high quality everything, well laid out.
Being based on the Revox PR-99, looking inside and also seeing a tube output stage and wireless remote, there are not many parts that are original Revox. This is basically the same thing that UHA does with a different chassis.
Interesting discussion here: http://www.tapeheads.net/showthread.php?t=23179
Older thread I know but I had a chance to hear the newer version recently (ATR10 mkII) and was thoroughly impressed. Had a chance to hear the same music on that and a Select DAC and everyone in the room preferred the R2R. Seriously thinking about buying one! Been a long time since I did anything with tape though ...
George
George
What type was being played?
If you're asking what type of music it was Dire Straits On Every Street that Sonorus had put through their SHI mastering process. The demo system consisted of the VAC Statement Pre and Statement 452 mono's with VSA speakers ... I think the Ultra 7's if I'm not mistaken. The MSB Select was fed by an Aurender N30SA. Not sure which cabling was in use or which audio stands. My caveat with what I heard was that since the recording on the tape had been put through their SHI (Sonic Holography Imaging) recording process I'm not sure that the comparison is apples to apple ... pretty sure its not actually ... but it did sound amazing either way.
I'll be trying the Statement system at home at the end of November which I'm really looking forward to! Might see if I can get the tape deck home at the same time.
George
I think Kevin's VAC Statement electronics are wonderful!
