Republicoftexas69
Yes SPF and go fiber.Nothing anyone can suggest then, unterminated ethernet cable, a step up from Blue Jeans or Supra Cat8.
Sells by the metre.
Sells by the metre.
My reaction to the Starlight was similar to your reaction to the Furutech, but that it was messing with the high frequencies wasn't apparent until I compared it to a few others. The Platinum Starlight seemed impressive at first but it made bright recordings sound even brighter. I think it was the use of silver in each of those that didn't jive with my system. The Chroma uses only copper so no problems there. For the price, I thought it was a good value.I have tried the Furutech Lan8 NCF but there was something in the high frequency range that didn't jive. No matter where I put them in the chain it was unpleasant. I have ordered some WireWorld Starlight and Chroma to experiment with next.
If the Chroma is a step up from the Supra Cat8 then i'll be fine with it for now. Otherwise, I'll wait until I upgrade my switch before upgrading cables again.My reaction to the Starlight was similar to your reaction to the Furutech, but that it was messing with the high frequencies wasn't apparent until I compared it to a few others. The Platinum Starlight seemed impressive at first but it made bright recordings sound even brighter. I think it was the use of silver in each of those that didn't jive with my system. The Chroma uses only copper so no problems there. For the price, I thought it was a good value.
Ive just had the same experience with the Starlight v Chroma. The Chroma is a step up from the Supra cables but not enough for me to be content with them. I have my eye on the Sablon’s next as I am hesitant to try any other silver cable at this time.My reaction to the Starlight was similar to your reaction to the Furutech, but that it was messing with the high frequencies wasn't apparent until I compared it to a few others. The Platinum Starlight seemed impressive at first but it made bright recordings sound even brighter. I think it was the use of silver in each of those that didn't jive with my system. The Chroma uses only copper so no problems there. For the price, I thought it was a good value.
My only audiophile Ethernet cable is the one that connects my streamer to my EtherRegen. Fiber leads up to that and genetic cabling precedes all that.for those running Fiber Optics: do you use the same model Ethernet cable pre and post FO or do you place more emphasis on the cable post FO?
In my listening tests, ethernet always beats wi-fi. I don't have any deep understanding, but I have read explanations as to why:Not sure if someone has answered this question before, but has anyone compared Ethernet and Wi Fi ? If there is data buffer in the streamer/computer, it should not make any difference theoretically.
Hello and good morning to you, @audiobomber. I am assuming that your modem/router is in very close proximity of your source gear?In my listening tests, ethernet always beats wi-fi. I don't have any deep understanding, but I have read explanations as to why:
1. A wi-fi receiver receives all the wi-fi signals inside the home, and from outside the home from neighbours' systems. The correct address for the actual device has to be separated out from the various signals that are present. This extra processing causes digital noise. Ethernet sent from a switch is already sorted by the upstream switch, therefore less processing required in the device closer to the DAC.
2. A wi-fi radio is a digitally noisy device, and digital noise gets folded into the data signal. Wi-fi waves can also infiltrate cables and components in the audio system causing RFI.
A wi-fi system is galvanically isolated, which is great, but the above disadvantages overwhelm the advantage of galvanic isolation, IME. Fiber optic combines the advantages of both systems, but that's another story.
When I've compared wi-fi vs. ethernet cable, the biggest difference I hear is a more solid or present sound through the copper cables. The sound from a wi-fi system is more ethereal.
