SET amp owners thread
My recently completed SET project amp. The B+ and filament power supplies are in two separate rack-mounted chassis which are connected to this main amplifier via umbilical cables. My speakers are Altec Lansing A7-500 which are using active crossovers at 500Hz - this SET is driving the high frequencies and a McIntosh MC240 is powering the low frequencies.
There is a thread here with the details of the build.
hi, what are the drivers in the A7? And is the crossover standard or something you have changed?
I use 802D and I also have a pair of Frankenstein drivers I made while I worked at Altec in Anaheim which are 902 with the Tangerine phase plug removed and replaced with the regular 802 phase plug. The woofers are 416-8-B.
The crossovers are all active line level - there are no passive crossovers in the system. The diaphragms for the HF drivers are custom ones I made while at Altec which are 4 ohm instead of 8 or 16 ohm. I've modified a number of existing 8 ohm diaphragms for 4 ohms but it is trickier than building them from scratch. This 4 ohm modification reduces mass considerably and allows for better high frequency extension. The link below leads to a page which goes into detail.
Any reason why you prefer the regular phase plug over the tangerine version?
The Tangerine sounds very harsh to my ears. I tried to like it, I really did, but it just doesn't cut it for me.
Reactions: adamaley
We'll be waiting patiently for your impressions.
First impressions are WOW! Om my VOTT the SQ is just on another level compared to the SS amps. The room is huge and the separation of the instruments/voices is simply fantastic. The only issues is the transformer hum that is clearly auditable as the 817 are extremely sensitive… but I guess that’s the nature of zero FB design!?
Reactions: morricab
Are the filaments of the 211 tubes being run on AC or DC?
That sucks regarding the hum. Are there no hum adjustments dials?
Reactions: the sound of Tao
Not universally no … however what matters most, and more importantly, is your delight in how you are connecting to your music in such a revelatory way , enjoy your evening :)
Reactions: Norway
The airtight 211 hum is mentioned here
Apart from the hum both amps are totally noice free, no hiss from the 288/1505 or UHT. The level of hum is not affected by the attenuator (gain/volume adjust) on the ATM-211
Yes! I was aware of this issue. And frankly I don’t really care as the SQ more than compensate for this minor issue.
Reactions: bonzo75
Yup …A good Ol In circuit ‘Hum Bucker’ altho there are several very good ‘plug In’ products on the market these days
Balancing the heating voltage does not always help with direct heating tubes. but usually the hum afterwards so low that is tolerable.
