LOL!!!! I'll keep that in mind...Also I think an adapter may be needed!It's not your head you'd be shaking if you mixed them up, John.
Steve Z
Steve Z
Will the Taiko BPS be able to power the extreme, switch and the router?
Yes.
When do you estimate you will have the upgrade configurations figured out along with pricing? August 1?
200nV at very low frequencies, like below 10Hz, lower above. That noise stems from the chemical processes in the batteries. Lower then realistically attainable from a LPS.Emile
Have you measured signal to noise on the bps E?
If so, can you share that please?
@Taiko Audio
Hi Emile,
Have you had a chance to look at the Extreme BPS chassis?
Do you think you'll be able to show a prototype any time soon?
Cheers,
Thomas
Hi Emile,Yes, we’re machining prototypes, but we’re taking a bit more time with a focus on ease of assembly. The Extreme as it is very labour intensive to assemble and its ordered in far larger quantities then we ever expected it to be, so we never looked at it from that angle. So we’re now trying to reduce manual labour as much as we can in exchange for increased CNC machining time as CNC machined are relatively easy to add, but finding good personnel in The Netherlands is less easy. BTW we are hiring, so if you’re reading this and want to join our team in Oldenzaal, drop me a note! We’re looking for people with managing skills, able to reinforce our support team, good English writing skills, no 9-5 mentality, and obviously, be exemplary in providing a great customer experience!
If it may help, I'm proficient in English and can curse fluently in 6 other languages.Yes, we’re machining prototypes, but we’re taking a bit more time with a focus on ease of assembly. The Extreme as it is very labour intensive to assemble and its ordered in far larger quantities then we ever expected it to be, so we never looked at it from that angle. So we’re now trying to reduce manual labour as much as we can in exchange for increased CNC machining time as CNC machined are relatively easy to add, but finding good personnel in The Netherlands is less easy. BTW we are hiring, so if you’re reading this and want to join our team in Oldenzaal, drop me a note! We’re looking for people with managing skills, able to reinforce our support team, good English writing skills, no 9-5 mentality, and obviously, be exemplary in providing a great customer experience!
Woofer & Tweet cartoon I’m sure is forthcoming — man on side of the road with sign board “will work for server (and switch, router, BPS)!Yes, we’re machining prototypes, but we’re taking a bit more time with a focus on ease of assembly. The Extreme as it is very labour intensive to assemble and its ordered in far larger quantities then we ever expected it to be, so we never looked at it from that angle. So we’re now trying to reduce manual labour as much as we can in exchange for increased CNC machining time as CNC machined are relatively easy to add, but finding good personnel in The Netherlands is less easy. BTW we are hiring, so if you’re reading this and want to join our team in Oldenzaal, drop me a note! We’re looking for people with managing skills, able to reinforce our support team, good English writing skills, no 9-5 mentality, and obviously, be exemplary in providing a great customer experience!
Fred Beckey was the man!!! He lived for climbing...The original Dirt Bag...A gifted climber...
I first starting hearing about him in the 90's when I was playing around Annapurna...
Joe,I read some posts in this thread about hooking screens into the back of a Taiko and installing this or that, modifications, etc. Is the Extreme plug and play like the N30SA, Grimm or do I have to do stuff?
The reason why this is important “to me” is that I have physical limitations that would prevent me for doing a lot of what is in some of these posts. I require a simple solution - plug and play. I have someone who would do the initial install, but can I then just play music?
Thanks in advance.
Despite my having suggested that people plug a screen in etc, I have never had to do that in all my years of owning my extreme. It’s an option available. With the other servers you mentioned the only option might just have to be send back to factory. I do feel it’s pretty much plug and play.Joe,
Great question. I've also been following this thread but feel intimidated by the DIY complexity of Taiko. Is it viable at this time for a "plug and play" solution?
The Extreme most certainly normally is plug and play. It's just when you encounter an issue that we need to dive deeper into the system. Normally, we can remote access it and resolve the issue but if for whatever reason we cannot get access remotely, a solution can be to connect monitor and keyboard and walk through some settings under our guidance.I read some posts in this thread about hooking screens into the back of a Taiko and installing this or that, modifications, etc. Is the Extreme plug and play like the N30SA, Grimm or do I have to do stuff?
Thanks in advance.
