I have all Wire World cables on both of my systems. I just like the sound, and what they offer my system. They are not cheap, but what they offer for the price is amazing and very comparable to other costly high end cables.
It's great to find a brand that fits your needsI have all Wire World cables on both of my systems. I just like the sound, and what they offer my system. They are not cheap, but what they offer for the price is amazing and very comparable to other costly high end cables.
Agreed completely. All of the puzzle pieces need to fit in their place for you to see the final picture.My Audio Dealer who I trust very much is a WireWorld Supplier/vendor. I believe that pairing cables with a system offers synergy like pairing speakers with an amp.
Mike give Stealth Audio Helios a try we have heard dozens of high end Phono cables and Stealth Helios is no contender so much more natural, open, silky crispy highs, tight powerful bass and a midrange like midrange intended to be..... Since you are in US give send Alex sales Manager of Stealth Audio a mail i am sure he will provide you a Stealth Helios Phono Cable as a one of the foremost and respected Audiophiles in our community....! alexanderlobas@stealthaudiocables.comneed a 3rd high quality phono cable for my incoming Primary Control FCL arm (likely Etsuro Gold cart....maybe the DaVa), and not sure i can wait 9 months (if i'm lucky) for another LFD to be built.
just pondering a Nordost Odin 2+ phono cable. has anyone done any compares with Odin, Odin 2 or Odin 2+ and other phono cables. do these deliver?......or......? i know a few here have these.
I’m using a Stealth Helios on my Glanz / KeoCoralstone Diamond it was a significant upgrade over my Ansuz C2 and various Glanz / Japanese staples…If you have a Turntable/Ar/ Cartridge/Phonostage/Sut in the higher range do your self a favor and try a Stealth Audio Helios Phono cable i am pretty surprised that here on WBF such a wonderful true State of Art Phono cable is almost not known by the Analog advanced Analog fanciers this will set a new reference on Analog Playback..... http://www.stealthaudiocables.com/products/phono-cables/helios/
Good to hear your experience. There is nothing better than sitting in your living room listening to music with the feeling that you are in a lounge. What made you choose your setup?As well as the phono cable I received my First solid silver Coax interconnect between the CDT and DAC. OMG, I had no idea what a difference this solid silver cable was going to make. It is the Wireworld Gold starlite 8. I started to play Some cd music I frequently listen too, and all of a sudden I was sitting in a live lounge someplace, the musical separation is insane the clarity and musicality came alive and grabbed me. That is the easiest way I know how to describe it. Listening to this system now has my full attention.
Did you find the Vyda speaker cable forward and exciting in lower treble as well?Hi Tim
The Vyda phono was brand new. It did change sound over the 3 weeks I demoed it. When I say change I really mean the cable's soundstage opened a bit more, bass became better defined and the music delivery seemed to be better integrated. It never really changed it's character, however small but important changes in frequency response was important that I believe you would only pick up after listening for a couple of weeks, not hours.
I got to around 90 hours and it didn't change after 60 hours. I also had the Vyda speaker cable in for 100 hours prior to hooking up the phono.
Every other cable was either my own moved from other tables or the Valhalla V2+ bought used. After spinning the V2+ for several days now it is opening up - are are my ears opening up?
Tim, what are your thoughts on burn in. Real or are you burning your brain to a slightly different sound?
If you want to get off the cable game and simply get the most resolution out of the cable you need to go balanced. Cartridges are balanced sources (which is why you have that weird ground wire no other single-ended source seems to need...)
True, but mostly it isn't to provide better grounding and lower picked-up noise. Balanced signals have many pros, but they do have slightly more noise.To be fair an rca connector *can* be balanced if isolated from chassis ground and implemented correctly., since additional chassis ground wire has its own place to go...( ground stud )
How come mike L gets comments and not me lol.there are multiple schools of thought on phono cables. we can read about SME 3012r owners who seem to prefer certain vintage very modestly priced examples. no right or wrong to it. me; i'm more from the school of thought that with a .2mv-.5mv signal from a moving coil cartridge, a phono cable is an 'opportunity' to optimize information. a phono cable is an almost equal partner with the phono cartridge, to feed the tiny signal to the phono stage and there get boosted by 40db-80db. garbage in <-> garbage out. that cable will be very audible. more than any other piece of wire in your system it will limit or open up what happens. maybe some cartridges need to be tamed......maybe some others can benefit fully from being unleashed.
so possibly 'heroic' efforts are called for. like this one.....
LFD Cables (phono and I.C.) from the UK, cables as components
for the last 10 years of my high end audiophile time, i've mostly steered clear of the very top price level of signal cables. i did own some very 'uber' priced Tara Labs interconnects for a couple years chasing digital goodness with my Trinity dac and Golden Gate. impressive with their grounding...www.whatsbestforum.com
