THE COMPACT EVOLUTION ONE TAD-CE1TX
kimurastanley
258
292
150
Singapore
Technical Audio Devices Laboratories, Inc. (TADL) today announced the TAD-CE1TX bookshelf-type speaker system as the newest addition to its Evolution Series of hi-fi audio components, replacing its predecessor, the commercially and critically acclaimed TAD-CE1, introduced in 2014.
While inheriting the ingenious Bidirectional Aero-Dynamic Slot (ADS) port from its predecessor, the CE1TX features significantly upgraded woofer and midrange units to achieve further refinement in sound quality. The CE1TX embodies the design philosophy of TAD’s top-of-the-line Reference TX Series speakers to deliver the sound field and imaging performance of the highest level, for which all TAD speakers are known.
MAIN FEATURES
1) CST Driver delivers ideal single-point-source sound
The CE1TX boasts TAD’s proprietary CST Driver, which controls the directivity of the concentrically mounted midrange and tweeter over an extended frequency range from the point of matching phase. This culminates in clear and solid imaging, as well as natural sound field reproduction. The midrange cone controls the directional characteristic of the concentrically mounted tweeter to bring the phase and directivity of their output in line in the crossover region. The result is ultra-wide-range reproduction from 250 Hz up to 100 kHz by the CST driver alone, while achieving a natural attenuation characteristic and directivity pattern across all bands.
2) Tweeter featuring a beryllium diaphragm
The CE1TX uses a light yet rigid beryllium diaphragm for its tweeter, manufactured with our proprietary vapor deposition technique. We have applied our computer-analyzed optimization technique called Harmonized Synthetic Diaphragm Optimum Method (HSDOM) in designing the form of the diaphragm in order to achieve precise control of its divided vibrations and piston motions, which makes possible ultra-wide-range reproduction of up to 100 kHz.
3) Midrange featuring a newly developed magnesium diaphragm having a high internal loss
The midrange’s diaphragm is made of magnesium, which is one of the lightest metals and has a high internal loss—ideal characteristics for materials to be used for diaphragms. The application of hybrid chemical conversion coating and painting to the surface gives it additional hardness and a yet greater internal loss. The result is clearer, distortion-free midrange reproduction unaffected by unwanted resonance. In addition, resonance in the mid-to-high frequencies generated by interactions between the suspension and diaphragm is effectively controlled to achieve an even lower distortion and a greater transient response.
4) Woofer with a newly developed MACS II*diaphragm
We have refined the woofer diaphragm made of five layers of woven and non-woven aramid fabric to optimize the physical property of the shell-shaped diaphragm that integrates the center cap and cone into a single piece. The result is a richer and clearer bass and the smooth, coloration-free reproduction in the mid-to-low frequency range.
*Multi-layered Aramid Composite Shell Second Generation
5) SILENT* enclosure that combines strength and an outstanding vibration-dampening characteristic
The CE1TX comes in a SILENT enclosure, which combines sturdy birch-plywood braces with medium-density fiberboard (MDF) panels having a high internal loss to provide superb strength and an outstanding vibration-dampening characteristic. The addition of 10 mm-thick hard aluminum side panels further reduces the vibration of the cabinet down to a minimum. Moreover, acoustic absorbent chosen and placed inside the enclosure, based on meticulous analyses of internal standing waves, helps eliminate standing waves that would adversely affect the sound field and imaging performance of the speaker.
*Structurally Inert Laminated Enclosure Technology
6) Bidirectional ADS Port for rich, natural bass
The CE1TX has inherited the Bidirectional ADS Port from its predecessor. This ingenious design places slit-shaped ports (ducts) in both side panels with flared openings to the front and rear to allow air to flow smoothly through them. This design reduces port noise generated at high amplitude levels and keeps internal standing waves from escaping from the ports, resulting in a rich, responsive bass. The symmetrically placed port openings, both laterally and along the front-rear axis, cancel out vibrations from the port movement to deliver a natural bass.
7) Eye-pleasing tropical-olive-grain wood enclosure
For the enclosure of the CE1TX, we have refined the classy tropical-olive-grain wood enclosure of its predecessor to add a mirror finish that gives the illusion of a wet surface and makes the grain stand out. In the manufacturing line, skilled artisans spend hours finishing each enclosure with meticulous care, beginning with applying high-grade, clear coating to the surface and buffing the base coating and finishing with surface polishing.
8) Stylish stand specially designed for the CE1TX (sold only in pairs)
The TAD-ST2TX-K stand specially designed for the CE1TX is built with strength and a high vibration-dampening characteristic to bring out the best of the speaker.
Reactions: Stef
Some photos from recent Singapore Audio Show
Reactions: Amir
I had a chat with TAD CEO during recent Singapore Audio Show and he mentioned that the new CE1-TX is his new favourite speakers system.
Over the weekend, I had a listen to CE1-TX, electronics were Cary audio dms700, accuphase c-2150 and TAD M1000 power amp. I was quite surprised with the good sound and understood why it is his favourite speaker. The resolution and clarity is extremely good without being bright and fatiguing.Soundstage is enveloping. This set is less than 10 hours played and I expect it will improve more. Will listen again when more run in.
In my opinion, it is the best sounding speaker in the evolution series. I prefer over the bigger E1TX beside B17EAC7A-E003-465F-89D4-F2958B63E7E5.jpegC46D4231-D1E4-4C4E-8CCF-725C47991AB2.jpeg
In my opinion, it is the best sounding speaker in the evolution series. I prefer over the bigger E1TX beside View attachment 101475View attachment 101476
Beautiful indeed! The CE1-TX new release is a real success indeed with also much deeper bass than the previous one which was stuck between the ME1 and the E1. Did the TAD CEO told you when the Reference preamp C700 will be released? I also heard that a new Evolution preamp will be released to replace the C2000 (maybe to match the M1000 power amp design?)
PM-Ed you
Reactions: Tonari and Stef
New Review
Good evening,
has anyone had the opportunity to directly compare the "old" CE-1 with the new TX?
atb, Tom
Reactions: Bird509
I think this is the sweet spot in the TAD speaker line up. If you have a small Roon I think it will give you About 85-90% of experience the CR1tx
Good evening,
atb, Tom
I listened them both use same gear and set up at the dealer, but not side by side at same time, I would say the new TX are more “refined” than the old one. For me it is more close to the cr1tx sound especially in the base and mid.
Reactions: Stef and tom539
I am just messing around TOR is a great small speaker for $20k less. It is more efficient has bass and also goes well with the mola mola.
I am just messing around TOFs a great small speaker for $20k less. It is more efficient has bass and also goes well with the mola mola.
TOFs ??? (and I see nothing on Google...)
[please forgive my poor English]
No. Furthermore, I have never heard the CE-1 that you own. But two reviewers give us some clue.
I just see that two reviewers note a difference between the two models:
- French reviewer LeBeauSon tested the CE1 (not the CE1-TX). They noted that the CE1 (that you own) required the volume to be a little pumped up to "show" their qualities (do you confirm?)
- I note that Steve Guttenberg reports that the new CE1-TX can play very well already at very low volume. I am not sure Steve Guttenberg has ever heard/testd the CE1 you own.
If this is true, then:
If you live in a house, without direct neighbors, you probably don't care: you may crank up the volume with the CE1.
If you live in a block of appartments in town, as I do, it is a very different story; a CE1-TX might be preferable.
(Actually, I just heard the only CE1-TX pair touring in Europe (poorly partnered with Naim 200-series) as a "preview" at a dealer's. I listened to lieder (piano&voice), then 2 hours later I attended a lieder concert, 10th row, listening to exactly the same piece of music, facing the German barytone Benjamin Appl. Voices on the CE1-TX seem to be incredibly realistic and direct. Now, the home "context" -the appartment, the room, the...neighbors- have to be "prepared" for such a directness...)​
Amplifier question: I see you use a Devialet. Do Devialet/or yourself use a dedicated filter/impedance mapping (I don't know how to call that properly), that you downloaded, if only it has already been published for the TAD CE1? How would you describe its effect (with/without that "filter")?
Thanks.
I have listened to CE1 + Devialet 200 but it was not good
actually I listened to TAD CE1 + Vitus 025 , it was ok in small room , if you want full dynamics of TAD CE1 you should consider TAD M700 amplifier
Good evening,
atb, Tom
Hello Tom
According my TAD dealer, it is 20% more efficient thanks to the new woofer. More richer sounding at low volume level. Overall the speaker is more easy to drive.
Reactions: tom539
New Review from Stereophile
Reactions: Stef
Conclusion
My definition of the word "best," as applied to audiophile speakers, would include expressions like "extremely well-sorted" and "exposes everything" and "flawless tone." This thought struck me now because exactly these words passed through my head over and over during the hundreds of hours I spent listening with the TAD CE1TX's. These luxuriously appointed standmounts specialize in converting tiny signal currents into moving air with atomic-clock precision—all by itself, a captivating phenomenon to witness. But what elevated these new TADs to a level of performance I've rarely experienced from any speakers, anywhere, at any price is the coexistence of that atomic-clock precision with an innate ability to present instruments and voices in a most agreeable, seductive manner.
This TAD is the finest example of speaker engineering I've ever encountered. Absolutely Class A.
Reactions: Stef
Conclusion
Hi Amir. So do you think Herb Reichert is Audiophile Expert? I don’t know if I should put any stock in what he has to say? He is reviewer.
Thanks for your help.
Reviews should be expository. Did the review tell you enough about the product in terms that are meaningful to you?
I did not understand what was meant by the 'converting signal into sound with atomic clock precision'. Atomic clocks intend to be accurate. Does that mean the speakers are "accurate"? I don't know what that means either, but perhaps it is meaningful to others.
The speakers were tried with several different amps. That seemed like a good thing to do. Not many reviewers have multiple amps. From the series of vignettes, I gathered that each combination sounded different. It might be informative to use the same piece of music with each amp. I was unsure if there was any conclusion drawn on the overall character of the speakers beyond the above. Is there such a thing? The cable review was distracting.
My sense is that the reviewer described what he heard, and what he heard was connected to a reference of his own notion of instruments sounding in an agreeable, seductive manner. He was his own reference. You probably need to read multiple reviews from him to get some notion of what that is -- one review, at least that one review, is probably not enough to understand his values. Personally I get more out of comparisons that help me relate a system or component's sound to the sound of live acoustic music.
None of that is a comment on the TAD speakers.
