I agree that the Ear 912 hardly lacks dynamics and is all but not flat. At least in the 10k-20k price territory.I have heard the EAR 912 extensively with classic Mullard tubes rather than Telefunkens. In no way was there weakness, lack of dynamics, and flat sound. On LPs only, it has dynamic, lush and extremely dimension sound with Bryston big amps (14s or 28s?). I suppose the exact tube can be the difference maker here as on my amps, the difference between the driver tube of a 6UG7 RCA and GE is the difference between yuk and wonderful (the latter is 3D, lush, super dynamic and super open versus a closed in, less dynamic, smaller sound from the former). The 6SN7 cathode follower in those amps are also very sensitive to tube choice with Ken-Rad/RCA/Raytheon 40's-50's perfect versus 50's Sylvania Chrome Dome as too thin and bright and USSR 80s tubes-Yuk!
As you said , the Allnic combo is far more expensive. So it’s difficult to compare. If you compare the Audionote M10 to your Allnic, you will perhaps find the Allnic a bit lacking. However I didn’t heard the 100k M10. Just wondering.I enjoyed my EAR912 but it was a far better phono stage than it ever was a preamp - ultimately that's why I sold it.
The LCR phono section was hard to replace and I tried quite a number of quite well-reviewed phono stages that struggled to better it. In the end I went for an Allnic H7000V, and latterly replaced my external SUT - used also with the EAR912 - with the Allnic H5000 head amp. Of course the Allnic phono stage alone is similar in price to the EAR, and the phono-head amp combo is considerably more expensive.
Thankfully, the easy bit to improve on was the linestage, which I think suffers from EAR's stinginess in component selection. I ended up with the latest iteration of Audiopax Model 5 but in fact several linestages I tried including ones from Silvercore and Audio Research (Ref3) bettered it.
So I ended up spending double to get a significant improvement. Incidentally I tried various tubes in it including Telefunken (both in all positions and used partially), with variable results. I don't think tube rolling fundamentally makes much difference with EAR kit.
I have moved on to my 17 year old, unused EAR 864 paired with the EAR 890. I used Stillpoint Ultra SS under it. I replaced the line tubes with a NOS Mullard CV4004 for a wide frequency response, neutral but full bodied mids and wide dynamic range coupled with a cleartop RCA 12AU7. The phono stage has a D getter old Sylvania 12AX7 in front and double silicone rings on the rear two stock 12AX7s (JJ or Ei?). The line stage sound now has tremendous dynamics, extracts subtle musical cues, deep and wide soundstage and very wide frequency response (no lack of very deep, punchy bass here). Is it possible that it has a better line stage than the EAR 912? As Atkinson reported, he was concerned with the limited overload capabilities of the 912. It only has a stock fuse in it as does the EAR 890. Tried Synergistic Research blue fuses but the difference was too subtle (unlike their power outlets-huge improvements). Strange that those same type fuses made a remarkably huge difference on my large custom monoblocks.Still very happy with my 912 since 2007 into 509 anniversary mono blocks.
Very much a fit and forget situation and enjoy the music.
Hello,
Can you advise me ?
Apparently, someone enjoyed upgrading to copper caps rather than silver caps. http://www.troelsgravesen.dk/EAR-868L.htmI have an EAR 912 pre amp. I upgraded it with Tunsgram PCC88 nos tubes in the line stage and Mullard PCC 88 nos tubes in the phono stage. I also replaced the signal capacitors with Duelund 0,047uF JDM 600V Pure Silver.
Now the treble is hard and stinging. I have put the original tubes back in with no change.
Could it be the Duelund silver capacitors.
I read a story where an EAR 912 was put in with Jupiter copper foil/paper wax capacitors. Do you have any experience with whether they bring softness to the warmth of the sound.
(I listen to vinyls, Jorma cables, ATC speakers, Ayon power amp)
The Gik Q7D quad diffuser placed on the floor front wall between the speakers greatly improved the soundstage. Wow! Wall to wall sound (dependent on recording) on R2R, LP and CD, Wow! This in an already $150K custom built listening room. Took the speakers to another place.I have moved on to my 17 year old, unused EAR 864 paired with the EAR 890. I used Stillpoint Ultra SS under it. I replaced the line tubes with a NOS Mullard CV4004 for a wide frequency response, neutral but full bodied mids and wide dynamic range coupled with a cleartop RCA 12AU7. The phono stage has a D getter old Sylvania 12AX7 in front and double silicone rings on the rear two stock 12AX7s (JJ or Ei?). The line stage sound now has tremendous dynamics, extracts subtle musical cues, deep and wide soundstage and very wide frequency response (no lack of very deep, punchy bass here). Is it possible that it has a better line stage than the EAR 912? As Atkinson reported, he was concerned with the limited overload capabilities of the 912. It only has a stock fuse in it as does the EAR 890. Tried Synergistic Research blue fuses but the difference was too subtle (unlike their power outlets-huge improvements). Strange that those same type fuses made a remarkably huge difference on my large custom monoblocks.
As to the phono section, it sounds very good as is with a Dynavector 20X2L plugged into it versus using another set of phono cables with a Zesto Allesso SUT. It sounds more dynamic directly into the pre-amp which I suppose has inferior transformers to the Zesto but appears to be a perfect impedance match like the Allesso (at 100 ohms/max output).
I have also moved on for a year from the COS Engineering D1v. I found it lacked the body of music and foreshortened depth with my previous gear. Also, one neighbor in a $500K system was using Pangea power cables at the time. He replaced them with 6 GroverHuffman power cables and made a huge difference. I replaced the COS with an extremely modified Benchmark HDR1 (new filter caps, tantalum, power caps, new audio board, $50 audio grade regulators replacing 50 cent computer grade) Arcam Delta 270 CD player and Delta 250 transport with 15+ high quality audio filter, power and bypass capacitors as CD transport. The COS went back in now and has all the warmth and depth it was missing into the EAR system.
So, the sound I am receiving now is high end as indicated by visitors who have 50 years experience in high end audio (retailers and manufacturers). The speaker limitation is mostly in limited seating (imaging best in center seat only), larger ambiance (pending a quadradic diffuser), resolution (although I am hearing the subtlest details and dynamic shading as I've only heard in really expensive systems). The tonality is spot on. Dynamics are superwide. Bass from 6-12" woofers could have more texture but are super deep, comparable to subs.
Two friends and three local retailers told me to try the EAR 912 as it has fabulous sounding phono stage. The last time I heard it, it was tubed with NOS Amperex or Philips 6922 tubes. I read now that ECC88 (6DJ8) Telefunkens sound superior to the PCC88 (7DJ8). Really? I only know the Tele 12AX7s which I prefer not to have in my equipment.
I suppose I will try the 912. It is possible that the 912 limited overload situation doesn't exist on the 864 and/or that the line stage is better on the latter. I intend to upgrade my speakers early next year (hearing Aequo Audio Adamantis and possibly Marten Bird 2 or Parker Quintet 2, can't afford the best, Von Schweikert Ultra 7).
How did it go with the new Caps?, are they easy to replace I have new Jupiters in the drawer awaiting!Thank you all for your good advice and ideas !
I think I will order copper capacitors.
