As far as the remote iPad goes, have you compared direct cable Lan vs WiFi to iPad?The router itself will be around 6K. A currently significant unknown part of that is support cost, which is greatly impacted by how "plug&play" it is. I have some positive news in that area as the way it does currently perform best here can actually be supplied as a "plug&play" package, which we're working on right now. Let me elaborate on that:
The most support intensive option would be to use our upcoming Router to replace your current Router serving your entire network where you create separate networks for your audio system and your other home network devices. This was the original goal, and still is an option, however it is not the best performing option from a sound quality POV.
We get the best result by far by using the Router to create an exclusive audio network consisting of 5 devices:
1) Router
2) Wi-fi Access Point (AP)
3) Switch
4) Server
5) Remote control device (Ipad or Android tablet)
A schematic overview:
This is less complex then it looks, a quick and "dirty" test setup:
The best description I can come up with what this setup "adds" is stability. It creates a silent / black background in which images are projected with absolute stability, floating in air. There's also a significant increase in detailing, texture retrieval and soundstage, which is larger, airier and more enveloping at the same time, but the stability of it all is what stands out most for me, and this is somewhat of an eye opener as adding more devices to the Router degrade this stability, creating a somewhat diffusing effect and diminishing image positional precision. The amount of "traffic" created on your home network does not affect this stability, we tested high data rate downloads, 4K video streaming etc, this is virtually undetectable where it does noticeably impacts things without the Router in place. Another interesting discovery is remote control device to server connection speed/latency has an effect, faster is better here, a faster Ipad, or a less cluttered Ipad with less apps which create background activity installed sounds better. And this goes for both local file and streaming playback.
We're currently testing multiple Wi-Fi Access Points (yes @Kris the TP link 660HD is amongst them), and Wi-Fi provided by the Router by means of PCIe M2 (internal) and USB Wi-Fi adapters (external).
More to follow soon!
Dear Emile,The router itself will be around 6K. A currently significant unknown part of that is support cost, which is greatly impacted by how "plug&play" it is. I have some positive news in that area as the way it does currently perform best here can actually be supplied as a "plug&play" package, which we're working on right now. Let me elaborate on that:
1) Router
3) Switch
4) Server
Very interesting! I was not planning to replace my existing Modem/Router and was intending to install the Taiko Router between my existing Eero 6E satellite/base station in the Media Room and the Taiko Switch. Sounds like this will be best for SQ as well, which is great.
Now, my Apple TV “X” [heavily modified ATV] is connected to the same Eero (via Ethernet). I mentioned earlier that with the new Network card and Switch, the sound quality of the ATVX improved significantly (similar to how Emile described it above for the Extreme).
I suppose everything connected to the Taiko Router should get a reduction in background noise, correct?
Like this?
(note no wired connection between the Taiko Router and the main Modem/Router.)
It seems to me that the router is going to be the most complicated new device to integrate into different Taiko users systems vs. the NIC card, Switch, BPS, TACDA/TACD.
I don't expect an answer to my scenario below, but it is an example of how looking at what I currently have installed and looking at the proposed Taiko Router possible configurations, makes me "scratch my head" and compose this post.
In my set up I have a Verizon ISP router that needs to be in the system for various tv/set top box reasons, then off one of the ports of the Verizon/Fios router I connect to a
Araknis-DUAL-WAN GIGABIT VPN ROUTER AN-31-RT-4L2W to distribute to 20 locations throughout the house.
I have six each Araknis Networks AN-510-AP-I-AC AP's that are connected to hardwire connections from the ARaknis router located throughout the house.
My audio network (Extreme/Ipads/Macbook) that supplies hardwire to the Extreme and wireless for control via the AP's throughout the house is from the Araknis Router.
If I run the Taiko Router off of the Verizon router then how would I be able to utilize my six AP's that are already in place and connected to the Araknis router.
So, this is an example, and my question is will Taiko be helping people (like me) figuring out the best set up or will that be up to each individual to sort out their optimum network that meets the needs of the audio network as well as the rest of the required network for the other 20+ connected devices in the home?
I don’t use WiFi for anything, so with the Taiko Router/Switch combo feeding the Server, I would use a 2nd switch (Cisco) off the Taiko Router to connect to the iPad remote. (assuming this configuration will still allow the iPad to function as a Remote?).
Dear Emile,
I have two separate internet services in my home, one is fiber, going to the Audio Network, and one is copper, going the home network, so they are completely isolated. In this case, which option should be better:
a) Program (if possible) the Taiko router in order to use it directly with the fiber input
b) Keep the current fiber modem and router, and place the Taiko router in series
Thanks.
Keep existing house router/wifi access point. Use Taiko router in series and create an audio exclusive connection to hifi for best sound?
Thats what I'm doing and my router will be sitting beside my switch with the Extreme on the Shelf above. My network is fine the way it is. My inly goal with the Taiko router is what it does to SQ. in my sound system. I have zero desires to use it in the house replacing my whole system router. I do understand that replacing ones router completely willl create the most customer service requests. IMO we should take Emile's advice and use it the way he suggested. Aren't we all wanting superior SQ and this seems to add an even greater uptick when placed in series with the house router.
Steve, this works for you. I have three different rooms on different floors running off of the Extreme that I need Ipad control for in the various rooms/floors. Everyone's set up is not going to be as simple as your set up. What works for you might not work in all network situations.It's been a while since such a meaningful pearl has been dropped by Emile.......to me this is as good as it gets as it is the option I plan on using. My router will sit beside my switch and have nothing to do with the rest of my home network ...
This could be the pearl. of the month...
Emile, in a configuration: Modem-Router (ISP) - Taiko Router- Taiko Switch, if the Modem-Router (ISP) already has Wifi access, is it still necessary to add a Wifi access point connected to the Taiko Router?
My suggestion is:
1. Taiko to provide a pre-configured plug&play solution as outlined in this diagram:
2. Provide support for this scenario only, and only for the part called "Audio Network" on the diagram above. Have a way to easily rollback to factory default settings (i.e. the config above).
3. Contract with an external consulting/support company that can provide paid support for any other configuration/variation.
4. Stop being so nice and enforce #2 & #3. Otherwise, as a small company, it can easily drown in home network support. And that won't be good for any of us.
That is indeed the intention, we’d supply a complete Plug&Play preconfigured package, AP included. And indeed support would be a nightmare on deviating configurations, not to mention the loss of guaranteed SQ performance.
No, that's my issue. I need one for almost every room as they are stone and brick walls....ughDoes one AP create enough coverage for all rooms?
This was my point. I still believe that I will need further network support and I agree Taiko should NOT be offering this free support.My suggestion is:
