Has anyone managed to fit a spade of one of Shunyata's new ground wires into the Switch's ground screw? If you have succeeded, I would appreciate if you send a picture.
Yes, I have. I am using the smaller 4-6mm spade.Has anyone managed to fit a spade of one of Shunyata's new ground wires into the Switch's ground screw? If you have succeeded, I would appreciate if you send a picture.
I am using a Granite Audio Ground Zero ground cable which attaches to a Shunyata Everest. Perhaps my spade is slightly larger than the spadeI'll give it a try when I put the DAC cable in.
Perhaps for successive chassis, you could make the base where the screw sits about 5mm larger, I think that would solve the problem.
Regards
My mistake, perhaps my spade is slightly smaller than yours.I am using a Granite Audio Ground Zero ground cable which attaches to a Shunyata Everest. Perhaps my spade is slightly larger than the spade
you are trying to attach here. It is a tight fit but I was able to make it work.
You probably have the larger (6-8mm) spade from Shunyata. I used the smaller (4-6mm) size and had no issue connecting it to the Switch. Hope this helps. (Can't get a photo because my Switch is "buried" under a bunch of stuff; but trust meI was finally able to insert the spade, loosening the screw a lot, not ideal, but it works.
The waiting is like bring a kid and knowing you’re going to get something good in the next few days.
I just got all tracking info and mine has cleared customs and I have a Monday before noon guaranty delivery and here I am already looking out my window.
pretty amazing for a solution to a problem many of us were having with the new network cards. So from report of issues to doing deep dive investigation of cause with a multitude of very expensive engineers the cause was quickly rooted out and heat sinks were added after firmware changes resulting in not only a fix to the problem but some more improvement in SQ. Oh, and did I say no charge to any of us all in under 2 weeks.
Customer service to we users as always has been essentially painless as we will be receiving return labels for the old card soon after we receive the new card.
