On my drill press in the garage shop. I just eyeballed it. I hope this was the old throw away bracket or I would have measured.
The copper gets kind of bendy with all those holes.
Not fully tested yet. I just put the top back on so start the clock.Does this control the problem
No endorsement of Amazon intended, but this is typical of what is out there.This is what I think I did - I used the 2 wood blocks the new bracket is shipped with. But with a hand drill punch you don’t need to.If you clamp a piece of wood or metal to the bracket while using the drill press (or even if you are using a hand drill) the holes will be truer without as much bend or give around the holes. It will keep it more rigid...
If a piece is flush to one side it will just make a neater job. It sounds as though this is what you did. I would also use a cone shaped bit.This is what I think I did - I used the 2 wood blocks the new bracket is shipped with. But with a hand drill punch you don’t need to.
Our miniature schauzer Phantom provides the encouragement around here. Very non-judgemental (as long as she gets her head scratched), which is good....it sounds like Emile has a solution in hand, but if heat is a concern short-term and cover-off is a no-go, it looks like one could either remove that square-ish copper plate adjacent to Slot 1 or the Slot 1 mounting bracket (if unused), or both, if powered off anyway. That's a pretty good size opening for airflow. Not that drilling holes ain't fun. My head is full of them.
BTW: I was able to get the new bracket/card installed this evening. The new bracket required a little *coaxing* even after final QA from Jacky!
It seems as if others were up in a jiff, but I had difficulty starting things, rebooting, starting services, etc. Ganbatte! (persevere) as they say in Japan. OMG. Sounds nice, but I could use a wee dram.
Hang in there, Richard. I was getting 1-2 hours with the top cover on, days and days of 24/7 with the Extreme's top cover off.Well that did not last long. I will try again with the top off
It was a good effort anyway...Well that did not last long. I will try again with the top off
