...mark your calendars: Daughter-board Rolling has arrived! You gotta love this thread!
I have to ask the question therefore.......are these daughterboards plugnplay? I ask because the daughter board I had in my system years ago was hard wired to the motherboard. IOWis it as easy as a simple remove one daughter board and plug in the other without wiring being needed...mark your calendars: Daughter-board Rolling has arrived! You gotta love this thread!
will each daughter board be priced the same or will it be more for the DigitalYes!
I thought Christiaan and Emile said the USB board is replaced by the new one and USB goes awayCan we retain the Taiko USB board as well as having TACD and switch output between two different DAC’s?
Understood, it is the logistics that concern me...I keep wondering (and this is way out of my scope) if Lampizator can have an external modular piece to complete the interface...For my understanding is it correct to infer that in order for the new interface to function the DAC must also have the same interface and so far there are 4 manufacturers who seem interested. So is there a benefit to use the new card and remove the USB card if I am keeping my DAC (which I love) which lacks the new interface. I can see there are logistics to this as well
I thought that might be the case, Thank You...That would probably defeat the purpose since an external module would need to interface with the Lampi via USB, AES or S/PDIF which would keep another interface in play.
Yes. USB is not used with the new interface card as I understand it and that Taiko would give some sort of buy back when you replace the USB card with the new oneHe said the opposite "USB will not be added, and as such, the TACD cards will not substitute the Taiko Enhanced USB card."
All too confusing for me.That would probably defeat the purpose since an external module would need to interface with the Lampi via USB, AES or S/PDIF which would keep another interface in play.
Isn’t the new interface “NEW” and therE has to be one in our own DAC
I guess where I am at a loss is trying to understand why I would want to replace the Taiko USB card which I love
Because Taiko has determined the new interface is superior to USB...I want both! - but that’s typical of me.
I know and never bet against Emile so to come back to the initial question it is my understanding that the new card replaces the USB card BUT Lukasz, MSB, dCS and TotalDac will need to change from XMOS to the new interface.My one concern is that the new interface provides me with the exact same ability to play all the formats that I can now. I can play to 768 and DSD 512 without issues using XDMSBecause Taiko has determined the new interface is superior to USB...
Good point, I find much of this daunting. Also, as earlier indicated, logistics is a big concern as to how all of this will be implemented...The thought of shipping the Horizon back to Poland does not make me feel comfortable. If it comes to that, I'll sell mine and buy one done with proper implementation done from scratch...Yes fair enough, but how many USB DACs are there out there? If you jettison the USB output, you have a seriously hamstrung server. That’s ok if you know you, your Extreme and your DAC are set for life and you will never want to use another. I probably will not go DACD route if it means losing the USB output.
My hope is that a local tech could remove XMOS and install the new Taiko interface. When I had my Pacific it was using the outdated interface and all new Lampi DAC's were coming installed with XMOS. I could only use XDMS in a limited fashion and could only avail myself of its full function by switching to XMOS . Fred had a board shipped to me with a schematic as to how it was installed. I found a local technician who swapped it out in under an hour of work. I would hope for the same and have the work done locally.Good point, I find much of this daunting. Also, as earlier indicated, logistics is a big concern as to how all of this will be implemented...The thought of shipping the Horizon back to Poland does not make me feel comfortable. If it comes to that, I'll sell mine and buy one done with proper implementation done from scratch...
