I have already mentioned on the #99 that a friend of mine visited Tokyo around Xmas time and bought the MSL Gold cartridge there.Ok, I am just going to ask. How do you buy these cartridges directly in yen. US dealers list in US Dollars. Thanks.
Hi 'CKKeung',Hi Bonsey Jonesy,
Some thoughts of mine :
1. CH Precision is working on a P10 and probably will be ready in 2023. My guess is that it will have an included external PSU, similar to the config of L10. If so, will you still consider adding a X1 to your P1 now?
2. IMHO your MSL Eminent is outclassed by the other components of your LP system. The Japanese ¥ is lowish currently so it's a good time to upgrade it to Gold or Platinum. 3 weeks ago a friend of mine bought a MSL Gold during his Xmas vacation in Tokyo. After tax reduction & discount, it's only ¥590k.
3. Another target your may consider is your 4Point tonearm. The new Safir9 is outstanding! I auditioned it a few times and posted my comment on the WBF Safir9 thread.
Sorry all, some text went missing in one of my sentences when I posted i.e;Hi CH P1 Owners,
Have two questions regarding the earth connections on the P1 and the transportation bolt(s) underneath the P1 that should be removed after being transported / delivered before being installed in the P1's resting and operating place.
Reason I am asking these questions is I have (and always have since installing my P1 last November (bought used), hear some hum through my Hifiman EF1000 Headphone Speaker Amp and Susvara Headphones when the volume gets to around 50% onwards. Through the speakers it is much harder to hear the hum but it is still there.
Therefore I am wondering if
I have disconnected the tonearm lead (currently connected to the MC1 / current input of the P1) and the hum does reduce but is still there. So I know it is not the cartridge or the tonearm cables from my Kuzma 4Point 11" (connected to my Kuzma XL DC).
Earth Connections on P1
On my P1 there are three earth connections (for banana connections) at the back of the P1 i.e. the two upper ones in black and the lower third one in yellow.
I am using the yellow connection as the earth with an earth wire (green & yellow) going to a mains power supply hub earth connection.
And I am using one of the black connections (top one) for my black tonearm earth cable connection i.e.;
When I disconnect the earth connection from the P1 that is wired to the mains power supply hub earth connection the hum is louder.
When I disconnect the tonearm cable from the P1, the hum is louder.
Can anybody give me information as to whether my current earth connections are correct / optimal in reducing any hum from the P1 that may be due to earthing of the P1 as much as possible.
Transportation Locking Bolt(s) for P1 (or not in my case with my P1).
When I read version V1.1 of the P1 Manual it talks about in Section 4 to unscrew a transportation locking bolt from the P1 that locks the Transformer in place during transportation and unlocks it when removed.
When I read version V2.2 of the P1 Manual (most current version on the CH Precision website) it doesn't mention at all about unscrewing a transportation locking bolt to release the P1's Transformer.
When I look underneath my P1, it doesn't have such a transportation locking bolt like is shown in the V1.1 P1 manual, however I do see four smallish domed head allen key bolts arranged in a square pattern i.e. ;
I am therefore assuming that my version of the P1 (manufactured late 2019 (possibly Nov 2019) has no such transportation locking bolts to remove before siting and operating the P1, hence no information on such transportation locking bolts in the V2.2 version of the P1's manual.
Can anybody give me any information / reassurance on this for my P1 ?
Thank you WBF Members in advance for any help / advice you can give me to make sure I am using my P1 optimally to reduce hum as much as possible.
All,Sorry all, some text went missing in one of my sentences when I posted i.e;
'Therefore I am wondering if'......it may be the way I have the earth cables connected / arranged and whether I need to release / remove any transportation locking bolts from my P1 ?
Thank you 'mtemur' for your reply. Much appreciated.I have come across a CH P1 making hum with a highly praised tonearm a couple of years ago. IOT figure out the problem I tried the same tonearm with EMT JPA 66 and hum is gone. I also tried it with Kondo SFz and GE-1 and hum reappeared. it turns out the tonearm has a design flaw. Grounding is not very well thought but can easily be fixed and I fixed it.
Long story short CH P1 is very well designed device but some devices are more sensitive to hum. IME when no tonearm is connected grounding via power cord should be sufficient. There should be no additional grounding and no hum.
In your case I can only think of a grounding loop at power distributor/receptacle or a remote possibility of transport/transformer screws. IMHO it’s best to consult CH Precision directly.
Thank you for your reply 'adyc'. Much appreciated.No concern on locking bolt. Your P1 is the new version.
Hi CH P1 Owners,All,
Also forgot to mention that when I switch my Hifiman EF1000 Amp over to digital input (my Chord Blu CD Transporter with M Scaler and DAVE DAC) I don't get any hum at all...i.e. a dead black silence.
Same when I connect my CH P1 and Chord Blu & DAVE to my Chord Prima Pre-Amp & Mezzo 140 Power Amp (solid state pre-amp & power amp) i.e. hum from the P1 (same level as through my EF1000) and no hum at all from the Chord Blu & DAVE.
Therefore I know it is not the EF1000's tube pre-amp section causing the hum from the P1 and it's the P1 causing the hum !
I bought a Samsung Galaxy Tab A8 to use with my P1 last November. Still in it's sealed box as found I didn't need it as I could (and did) set up my P1 just with the from menu buttons.I am getting a P1. What is a recommended tablet for control. Does Amazon Fire works for this? Sorry, am an iPhone user, so not much experience with Android and it's apps. Thanks.
Sorry mis-type for 1st sentence / paragraph i.e. should read 'front' not 'from'I bought a Samsung Galaxy Tab A8 to use with my P1 last November. Still in it's sealed box as found I didn't need it as I could (and did) set up my P1 just with the from menu buttons.
Also have my P1 connected with an ethernet cable but haven't bothered using it i.e. with uploading updated software etc. as I am ok in how it currently sounds with my current UK based system.
p.s. I am also an avid Apple Macbook and iPhone user.
I have the MSL Eminent Ex cartridge on my Kuzma 4Point 11" and connected to the first current / trans-impedance input of my P1.Thanks for all the quick responses. I decided to get a 2022 Samsung Galaxy for now. I think in the beginning it will be nice to change settings and see how it sounds. Mine is coming with EQ board, not that I have 1950's vinyl, but might be interesting to see. Plan on using MSL Platinum and Solo on two Kuzma 4Points. Exciting. Will be selling Burmester 100. Do I really need to A/B that with P1?
