Site Founder, Site Co-Owner, Administrator
FWIW even my wife can navigate XDMS which is a tribute to the Taiko team
It is very intuitive with each new build
So it looks as if what will be released as a Taiko DAC will still be confined to a small part of the overall board real estate available. Is this correct?Hi All, here is a schematic representation of the TACDA PCIe card in its initially proposed fixed-output guise,
and in its revised Modular guise. Note that, for the analog output option, the DAC itself will be contained on the Daughter Board.
IIUC, the analog out is the one and only version with a DACI’m guessing the answer to this question would be, because it sounds better.
Similar to oldmustangs question above, if all of the other versions have the DAC on the card, why would the analog out be the only Version that has the DAC on the daughterboard?
So the new PCI modular card will have an output (connector to be revealed) for the new Taiko proprietary interface and also the daughter card connector with different outputs to choose from. Correct?
Indeed, only the Daughter Board will have outputs. The connector that is yet to be revealed is the one that will be used to transport the new proprietary Taiko TACDD format signal.IIUC, only the daughter boards will have outputs.
Matt
Indeed, only the version with the analog outputs will have the DAC on board. The DAC requires only a minimum of real estate.IIUC, the analog out is the one and only version with a DAC
Matt
Yes, that is correct for now. Nevertheless, your comment regarding a super-charged DAC section has been notedSo it looks as if what will be released as a Taiko DAC will still be confined to a small part of the overall board real estate available. Is this correct?
Steve Z
Steve Z
"Make it so ... and ... engage!"Well not necessarily. We can surely look into expanding options if it proves to be popular. We could even make a multi PCIe card setup. Slot 4 is not in use in any Extreme afaik for example, slot 5 is used by the UB card, slot 6 by the VGA connector which is almost never actually used, as good as redundant so we could even make a triple card setup, and each of these cards could have daughter boards, and then we could make external add-on boxes, but then we'd have become actual DAC manufacturers which we want to stay away from. I do prefer to spend our R&D resources on improving source and interface, where there still are strange new worlds to explore, where we can seek out new life, to boldly go where no man has gone before.
So two slots are occupied?Indeed, only the Daughter Board will have outputs. The connector that is yet to be revealed is the one that will be used to transport the new proprietary Taiko TACDD format signal.
This is not to do with PCI slots.So two slots are occupied?
Me tooI am more interested in knowing if the switch is still on schedule to ship by the end of February.
Me too...Me too
Im also interested in how many Extreme users will give up their outboard DAC for this option. Perhaps a new poll
Well, unless I can audition the new board in my system first with a full refund if I don't like it better than my current DAC, I'll never get to that decision point.Me too
For people who will change their current DAC...
