Good point!Just to clarify, Olympus Ten T only has ONE ground post, NOT 10. Do not confuse it with the Ten Ten.
That would not be my choice.Thanks guys. Would it make sense to try with two Olympus Ten Tungsten Infinity with the Eartha Apollo and Everest for each preamp (line and phono) as my dealer suggested?
A single 3 compartment box with three earth cables would be more effective unless it is simply impossible accommodate such a box whi ch would be unusual but may involve a compromise
Thanks FrankieIn my case, my Gryphon Pandora preamp has two chassis so, if I choose the single box solution (which I would prefer because of limited space available), I would need at least four posts to accomodate both my mono amps and my preamp. That would in any event leave all sources out.
It looks like two Pluton would probably be the best solution, since I could connect both only my mono amps, my 2-chassis preamp, my phono preamp and my dac. Very expensive, though.
What do you think?
Thanks.
Thanks. Would you also recommend using the grounding post vs. the signal post in the gryphon line?I have grounded my Gryphon Mephisto to the Tripoint Troy Signature years ago...using the grounding post on the back of the amp. It had the same positive effect as it did on the rest of the components...more quiet/lower noise floor, an element of detail floats upwards into the music that was not quite as legible...and that realism comes forth that extra bit. However, the impact was not nearly as great as the signal grounding benefits I got on the DAC and preamp.
What I meant about chassis is that the Gryphon Pandora preamp is a dual mono unit with two separate chassis (power supply is separated). So I will need to connect both separately.
I have contacted Gryphon asking about Entreq. They've recommended the grounding choice and had great words about Entreq but advised to use only chassis grounding and avoid signal grounding. I then checked this matter with Entreq and they said that there is no problem in connecting Entreq with Gryphon electronics using signal grounding.
Does anyone here have experience of grounding Gryphon electronics with Entreq?
I've decided to start and test two smaller units (Olympus Ten Tungsten Infinity with the Eartha Apollo) and if I like it (as I am sure I will based on the comments here and elsewhere) I will order two Nucles units with the Eartha Apollo cables. If all goes as planned, I am planning to connect the Nucleus to both of my Essence mono amps (separate boxes), the preamps, the dCS dac and my D'Agostino phono stage or the sOTM switch.
Placement would be most probably be behind the speakers on the sides of the rack.
Thanks for all your help so far
Thank you Frankie.
Hi Frankie,Thanks. Would you also recommend using the grounding post vs. the signal post in the gryphon line?
I have not thought I asked the distributor about the 2, and he strongly recommended in our system to go Pluton (ie, with Tungsten and Infinity)...and frankly, we went 2 Pluton + 1 Olympus Infinity Tungsten (so effectively 7 of those boxes in total)...and have been exceptionally pleased. Exceptionally. If you can, go with their best technology to start.Has anyone compared the Ten Ten vs (two) Pluton?
Hi...confusing I know. There is Tungsten (latest tech) and there is Infinity (preceding tech but still relevant).Thanks Lloyd. I thought that both Pluton and Ten Ten were latest tech, Infinity and Tungsten only on a smaller box (?).
Please look at the picture of the Olympus Ten T, the logo has the symbol of the Infinity. So it has the "Infinity" technology as well.Hi...confusing I know. There is Tungsten (latest tech) and there is Infinity (preceding tech but still relevant).
The Pluton and Hero have BOTH Tungsten and Infinity. I believe Ten has 'just' Tungsten. Cut and paste below from Entreq website.
Olympus Infinity T.
Olympus Tungsten has an Aura of confidence. The improved Infinity technology, the adjusted mineral mix, the special ceramic and Tungsten metals, and the new improved casework. All together gives Olympus Infi T a aura of solid trust and confidence. When you look at and handle this ground boxes, they tell you
“ Leave it with me, I handle it”
Both Ten Ten and Pluton are excellent products just below the Hero.Has anyone compared the Ten Ten vs (two) Pluton?
The dealer's suggestion is certainly an option and I certainly agree with his suggestion of Apollo earth cables. The Apollo range is the sweet spot of the Entreq range.
Good point! Thanks for the clarification.Please look at the picture of the Olympus Ten T, the logo has the symbol of the Infinity. So it has the "Infinity" technology as well.
Hi Barry,So,for example a Poseidon ground box and three earth cables. You can the connect the earth cables to the two separate negative output terminals of your mono amps and the third to a spare input on the Pandora pre amp.The resultant grounding is then tackling the signal pollution in the audio signals going to your pre amp and the negative speaker terminal grounding is both reinforcing that and addressing the EMI produced by the Essence mono power amps.
Hi there,Hi Barry,
I currently connect 3 earth cables from my Poseidon to 2 separate negative output of my Octave power amp and to a spare output RCA on my preamp with very good result. From your above guidance, the earth cable should be connected to input RCA, so am I wrong to connect to output RCA? Pls correct me if I'm wrong.
BTW, I'm thinking of more Entreq box for my Dac and music server. For Dac (USB input used), should I connect Entreq to the RCA input (Spdif) or RCA output (either left or right analog). My dac has a chassis ground terminal as well.
