Well, three days away from the thread and I am completely lost! What is the page address for ordering? When can we expect the switch using the current standard finish to be shipped if ordered now?
Happy New Year!
I copied a few of Emile’s posts describing the Switch here:
https://www.whatsbestforum.com/threads/taiko-audio-sgm-extreme-the-crème-de-la-crème.27433/post-844275
Order page is here:
https://www.whatsbestforum.com/thre...treme-the-crème-de-la-crème.27433/post-844091
Enjoy reading about the other ground-breaking innovations! It’s a bit overwhelming, but all great!
That was exactly me 1,5 years ago when ordering my Extreme online. VAT added a switch like little tip. :pBut then I realized since every country (even state) has differing VAT it makes sense to have prices quoted without VAT.
Oh yes, I'm not complaining that the price was expressed without VAT, the reason he exposes is logical. I just "complain" about the bloody 21% IVA.
We use the DAC cable to connect the switch to the Extreme. What about the connection between our existing router to the switch? Use a standard Cat 6 cable? Is the DAC just a Cat 6 cable ? Sorry a bit confused here
Is there a SQ difference between:
1. SFP RJ45 Copper (DAC) cable with predetermined length up to 7m
vs.
2. SFP with RJ45 Copper port + CAT5/6/7 cable (select different CAT5/6/7 cables to achieve desired length)
Amazing work Emile @Taiko Audio - clearly the fruits of many long and arduous nights/days of listening to an insane number of permutations on the switch/router theme!
Hate to switch focus away from all this excitement for a second, but now I have my new Horizon, I have a question for @EuroDriver or others who use XDMS.
With TAS, when playing DSD I notice that TAS will transiently drop back into PCM between DSD tracks (for instance when you hit next track or previous track). With some DACs this results in a "pop" of varying loudness.
Does XDMS still drop back into PCM between DSD tracks?
Thanks and Happy New Year!!
The new technology interface card is CPU / PCIe direct to DAC - Analogue out AND CPU / PCIe direct to SPDIF (with rca, bnc and toslink connectors)
It does not replace the USB card
Its exciting technology leading to a whole range if future technologies.
Hi Emile,
You are an erupting Innovation volcano!
Big thanks and congrats!
I'm so happy that Lampizator/MSB/Totaldac are willing to collaborate with you on the new Extreme interface card.
I would like to ask one question :
If there are the USB card and new ethernet card installed in the Extreme already, there seems to be no spare PCIe socket for the coming Extreme interface card?
Do the usb card have to be removed to make room for the new interface card?
Many thanks!
Emile.. My DAC is not network capable. I assume the switch+network card still has significant impact on the sound quality? BTW, I only play from local folders - thanks
You may use unshielded twisted pair copper ethernet cable with RJ45 ends if that is what you are using now. If your existing router has an SFP cage you may use a passive DAC cable *if* the distance between your existing router and where you will put the Taiko switch is 7 meters or less. Taiko will include an SFP specific for RJ45 with the switch if that is what you specify. If you plan to go with a passive DAC cable from router to Taiko switch and the distance is less than 7 meters you can specify that in the notes when you order on the Taiko website or with your dealer.
A passive DAC cable is generally twinaxial copper (I haven't come across any that are other construction, but I haven't extensively researched this) and is not a Cat 6 cable.
Steve Z
I also don’t stream and yes, Emile assured us that the sound quality improves for local playback as well, with the new switch.
Reactions: theaudiogeek
Steve Z
Steve I was under the impression Emile veered from UTP Cat6 twisted ethernet (unshielded) with the new switch. Perhaps I misunderstood? Lots of in coming information. I do know previously, he was a proponent of Cat 6 unshielded. He'll have to elaborate.
There is no VAT in Hong Kong!
Most welcome WBF members to ome visit us for the delicious Chinese cuisines and for tax-free shopping.
:D
Reactions: oldmustang
Guys, as benign as it may seen, discussion of taxes and government spending falls under the category of politics and is not permitted.
From switch to network card the cable is passive DAC cable (<7.0 meters). That is a change specific to the switch/network card combination.
Into the Taiko switch from the rest of your local area network can still be RJ-45 unshielded twisted pair (UTP) commonly CAT5, 5e or unshielded CAT6.
However, if and when someone purchases the Taiko router, they can continue to use RJ-45 from Taiko router to Taiko switch, or if the Taiko router and switch can be connected with a passive DAC cable < 7.0m the two can be connected by passive DAC for a slight improvement in sound quality.
Clear as mud?
Steve Z
Clear as mud?
Steve Z
I understand the Passive DAC Cable. I must have gotten my wires crossed (or cables). I thought Emile referenced something different from the router to the switch. I get RJ45 but I thought he said NON UTP.
The bottom line is you INSERT the switch between the network cable you currently use and the Extreme. Then you can also get the new SFP networkcard.
Scenario A: You purchase the Network card and the Switch package which includes a DAC cable
Option 1: You currently use a cat5 or cat6 or cat7 or cat8 / UTP or STP network cable with RJ45 connectors, also often referred to as a copper network cable, you remove that from the Extreme, plug it into the switch and connect the switch to the Extreme with the DAC cable.
Option 2: You currently use fiber into the Extreme. You remove the fiber cable from the Extreme, plug it into the Switch and connect the switch to the Extreme with the DAC cable.
Scenario B: You purchase the Switch but not the network card.
Option 1: You currently use a cat5 or cat6 or cat7 or cat8 / UTP or STP network cable with RJ45 connectors, also often referred to as a copper network cable, you remove that from the Extreme, plug it into the switch and connect the switch to the Extreme with another cat5 or cat6 or cat7 or cat8 / UTP or STP network cable with RJ45 connectors.
Option 2: You currently use fiber into the Extreme. You remove the fiber cable from the Extreme, plug it into the Switch and connect the switch to the Extreme with another fiber cable or a cat5 or cat6 or cat7 or cat8 / UTP or STP network cable with RJ45 connectors (which I would strongly recommend in that case).
