ISO quality AES/EBU cable. Or should I consider Toslink.
Echolane
145
35
160
California
I think I have an above average system and I’d like to make it better if I can. I do almost all my listening via streaming and about the only way I can improve it is via cables and power cords. I’ve been reading about AES/EBU cables and quickly came across reviews that insist Jorma digital cables are the best. Lowest price seems to be around $900. Are they worth it? Other options?
I am assuming I shouldn’t consider Toslink due to its limited bandwidth.
The musical chain I’m dealing with is this:
Roon Nucleus > Ethernet > Audio Alchemy DMP-1 > BJC AES/EBU Cable > Berkeley Audio DAC Reference Series 2 > Audiomat Prelude Reference MKII integrated tube amp > Quad ESL-63 Speakers
Unlikely.
Reactions: lordcloud
The first thing I would do is remove the Ethernet link and put the Roon core next to your DMP-1. Transferring data over a local network will degrade sound quality. Try it out!
